Lift 4cylinder 2wd tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hgma44, Sep 14, 2019.
  1. Sep 14, 2019 at 11:47 PM
    hgma44
    hgma44 [OP] New Member
    Hugo
    2000 tacoma 4cy
    Wheels
    i bought a 2000 4 cylinder 2wd tacoma. I bought it to use for work (construction) . I love the gas mileage it gives me but at work i sometime have to drive thru rough terrain, nothing crazy, what will you guys recommend to get thru that terrain, i was thinking 4.5 inch lift and some
    Bigger tires. I know i will lose some mpg but thats still fine, my previous teuck was an f350 V10 so i wont complain about it loosing gas mileage. Thanks
  2. Sep 14, 2019 at 11:58 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    The problem won’t be mpg. The problem will be power. Or lack there of. A 4 1/2” lift will have to be a drop bracket lift. Or some ungodly spacer cool combo. Either way you’ll end up putting 35’s on it to make it look proportionate. Then you’ll be required to regear. And I may be wrong but I still believe that motor will struggle to power that heavy of a tire.
    Also, most of us here weren’t born yesterday, we know that a 4.5” lift isn’t necessary for the rough terrain on job sites. You’re trying to justify work as an excuse to mod your truck. Which is whatever it’s your prerogative. But the best way to lift Tacomas is 2” with coils and Add a leaf systems and put it on 31’s and regear.
    But to each their own.
    I suggest you use the search function as this has been gone over probably a thousand times (and that’s not a bad guess)
    Black DOG Lila likes this.
  3. Sep 15, 2019 at 7:49 AM
    hgma44
    Hugo
    2000 tacoma 4cy
    Wheels
    Not really trying to justify nothing bro, if you tell me leaving the tires as they are and just level it will get me through the job site ill do that. Thanks! Ill consider that 2 inch lift
  4. Sep 15, 2019 at 10:11 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Do you have a 6-lug or 5-lug. It’s considerably more of a pain in the ass to lift the 5-lugs because there isn’t as much aftermarket support for them as the 6-lug 4x4’s and PreRunners.
  5. Sep 15, 2019 at 11:35 AM
    hgma44
    Hugo
    2000 tacoma 4cy
    Wheels
    Its a 5 lug, little 2wd 4 cylinder tacoma. What kit would you recommend and what size tires? Im new to all of this
  6. Sep 15, 2019 at 3:33 PM
    UnderFire
    UnderFire Well-Known Member
    I'd just go with a little beefier wheel and tire setup. 27x8.50r14 on 14x6 wheels is what I've seen before. Maxxis has a nice lineup to choose from. The bighorns, buckshots and bravos are all tough tires.
    oconnor likes this.
