Lift advice
Discussion in 'Suspension' started by tbmevent01, May 19, 2009.
  1. May 19, 2009 at 5:56 PM
    tbmevent01
    tbmevent01 [OP] @zombietacoma
    Dean
    Knoxville TN
    09 TRD Sport DC
    TRD exhaust,AFE CAI,debadged,mag light mod, King 2.5 resi rear, King front resi coilover, ICON Delta Joint UCA, Total Chaos Expedition LCA, Deaver Stage 2 expedition leafs, FNW wheels, LT285 /70 R17 Toyo Open Country AT/3s,Leer 100XQ,Wet Okole front and rear, Wheelers Super Bumps w/Ubolt flip, Full Prinsu racks,
    I have a question about about some work i just had done. I had 2 Icon C/O installed on my 09 and the Toytec AAL for the TSB rear springs. The lift is fine but I also have 275 70 17 Silent Armor tires that are razor close to the stock UCA. I thought i would be fine with the +1 size tires since someone here said they had them as well. Do I need to have the TC UCA installed now? Any suggestions. Also the mechanic said he couldnt adjust the camber or caster i forget, as 1 of them was at the max. Will new UCA allow for more adjustment? Thanks
  2. May 19, 2009 at 6:05 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    sorry, but r u kidding?all sorts of info on here about all that.again,sorry but i had to ask.im out of here.later
  3. May 19, 2009 at 6:09 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Yes the new UCA's will correct this. No it isn't something you need to do immediately. I finally changed my uca's after almost a year. I have 285/70/17
  4. May 19, 2009 at 6:12 PM
    tbmevent01
    Dean
    Knoxville TN
    09 TRD Sport DC
    Thanks. What lift do you have with the 285's? I thought about going with them but I did want to chance it without having a lift first. Tires were an impulse buy while in FL. Got lift done today.
  5. May 19, 2009 at 6:37 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I have a 3" toytec lift. To run 33' tires you will have to trim, but its slight and can be done with a razor knife.
  6. May 19, 2009 at 6:46 PM
    tbmevent01
    Dean
    Knoxville TN
    09 TRD Sport DC
    Thanks. Im prolly doing the 285's later when i decided what rims I want.
