Lift Advice!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SDTaco4x4, Feb 23, 2019.
  1. Feb 23, 2019 at 4:03 PM
    SDTaco4x4
    SDTaco4x4 [OP] Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Ok, so I'm finally planning on lifting my Taco, and I need advice. What I'm looking for is an even 1.5-2" lift, and I want to keep the factory stance - so not level it. I honestly mainly want it for appearance, so I don't need anything crazy. What do you guys recommend that won't break the bank.
    Thanks
  2. Feb 23, 2019 at 4:08 PM
    tcjacado
    tcjacado Well-Known Member
    I would go with 5100s on the corners and use the stock spring on the 3 rd perch.
    hiPSI, VaToy, JoeCOVA and 1 other person like this.
  3. Feb 23, 2019 at 4:09 PM
    SDTaco4x4
    San Diego
    That will keep the factory stance, right? Do I have to do anything with the rear leafs?
  4. Feb 23, 2019 at 4:10 PM
    tcjacado
    Yes sir, Just raises the front about 1.5 inches.
  5. Feb 23, 2019 at 4:12 PM
    SDTaco4x4
    San Diego
    Wouldn't that level the truck? I want a 1.5" life all around. Don't I have to do something in regards to the rear leafs?
    Sorry if I'm misunderstanding your post.
    tcjacado[QUOTED] likes this.
  6. Feb 23, 2019 at 4:15 PM
    tcjacado
    The rear sits about 1 inch above the front for factory rake.
    If you want that kind of lift use the proper ome or toytec coils with the Billy's. And put a 1 inch block in the back or use a aal.
    Block is cheapest.... aal is about 100. Depends if your hailing weight which way to go.
    SDTaco4x4[QUOTED][OP] likes this.
  7. Feb 23, 2019 at 4:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Most people lift the front 1.5 to level it with the rear to get rid of the raked look.
    With the rear you can add a 1" block and it will look good and lifted while removing a touch of rake.
    SDTaco4x4[OP] and tcjacado like this.
  8. Feb 23, 2019 at 4:25 PM
    SDTaco4x4
    San Diego
    Ok so just to confirm, if I want an even lift, I can do 5100's all around, with a 1" block in the rear to keep the factory rake?
    Sorry, I don't know shit about this. lol
  9. Feb 23, 2019 at 4:25 PM
    tcjacado
    You are probably going to need to do the needle bearing while you are in there.
    SDTaco4x4[OP] likes this.
  10. Feb 23, 2019 at 4:26 PM
    Bishop84
    Yes, 1" spacers on the rear leaf's are generally accepted, and you can change it later if you desire more lift or more load capacity.
  11. Feb 23, 2019 at 4:26 PM
    tcjacado
    Yup that's correct
  12. Feb 23, 2019 at 4:28 PM
    SDTaco4x4
    San Diego
    Do you know about how much I should expect to pay for this, installed?
  13. Feb 23, 2019 at 4:29 PM
    tcjacado
    The shocks are around 500 and the block less than 50 bucks. Then you PM @Speed Freek and have him do the install.
  14. Feb 23, 2019 at 4:30 PM
    SDTaco4x4
    San Diego
    Awesome. Thanks for all the help.
    tcjacado likes this.
  15. Feb 23, 2019 at 4:30 PM
    tcjacado
    We all typically shop with Marie over at @HeadStrong Off-Road
  16. Sep 10, 2019 at 2:37 PM
    migx333
    migx333 Well-Known Member
    as stated above, headstrong does have pre made kits. the most affordable but also has a lot of good reviews is the bilsteins 5100 + AAL package.
  17. Sep 10, 2019 at 4:53 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Yea, what he said. I did it on the 4th perch and a one once rear block, slight take. Worked for me.
  18. Sep 10, 2019 at 8:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Call Marie. She will help.
