Lift affects handling
Discussion in '1st Gen. Tacomas (1995-2004)' started by chilow, Mar 14, 2011.
  1. Mar 14, 2011 at 12:55 PM
    chilow
    chilow [OP] Active Member
    New to trucks, I normally drive sports cars and I LOWER them to get the most handling out of the cars. I have never owned a truck before, but I assume that once you lift a truck, the handling will suffer. I'm not trying to say that I want the truck to handle like one of the lowered cars I've owned, but I don't want the truck flipping on me if I encounter a hard turn. Is there anything I can do to improve handling after the truck has been lifted? Again, I don't have a background in trucks so any help will be much appreciated. Thanks!
  2. Mar 14, 2011 at 12:59 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Your assumption is correct.
    It's a truck...why do you want it to handle well? If you want good handling, buy a car.
  3. Mar 14, 2011 at 1:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Leave the sway bar on and don't F1 around turns and you should be good.
  4. Mar 14, 2011 at 1:05 PM
    spamy
    spamy Truck guy
    NorCal
    07 4X4 Tacoma Sport SR5 Access Cab
    It should enhance off road capabilities. Thats the idea, not just for looks. If you dont plan on offroading or towing stuff then stick with cars.
  5. Mar 14, 2011 at 1:11 PM
    chilow
    I know it's not going to handle like a car. Just making sure I got the right idea about how it will handle after a lift. I plan on using this truck as an all around type vehicle ( tow my car to race track events, offroading once every few months, take it to go camping, etc.) It will also be my daily driven vehicle.
  6. Mar 14, 2011 at 1:16 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    you can put wider tires and wheels with less backspacing on them to widen the track slightly. this will help regain some of the stability lost when lifting.
    my truck is lifted 2.5" and i ran it like that with stock tires/wheels for 8 months and didn't worry one bit about stability. it felt fine in the corners. granted, i don't drive very aggressively in my truck (that's what my motorcycle is for!), but it wasn't even an issue.
    i now have 15x8 wheels with an inch less backspacing and it does feel a bit more planted in the corners, so that may be a route you can go.
  7. Mar 14, 2011 at 1:19 PM
    macgyver
    Brad
    Canton, GA
    It's not going to feel like it's gonna flip or anything after the lift doing normal driving. We have some very curvy roads here in GA especially up where I live in the foothills of the N GA mountains. Just leave the sway bar on. I have Bilstein 5100's @ 2.5 on stock coils with 2" AAL in the rear and I don't feel like it handles any worse than it did stock. At the same time though I wouldn't dare drive it like I used to drive my accord I used to have that was lowered w/ suspension mods and wider wheels and stickier tires.
  8. Mar 14, 2011 at 1:21 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Mine handles about like stock. Its a little stiffer but its not a big difference. I don't ever feel like the truck is about to tip over or anything.
  9. Mar 14, 2011 at 1:24 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Not much different, just don't think you're truck is fast and furious and you'll be fine. New UCA's can help with the truck's handling.
  10. Mar 14, 2011 at 1:32 PM
    chilow
    Thanks for everyones input.
  11. Mar 14, 2011 at 1:44 PM
    gpend5.7sport
    gpend5.7sport Well-Known Member
    Gabe
    Houston
    2010 Toyota Tundra TRD Sport
    too damn many
    you could always get a new rear sway bar that is adjustable according to whatever lift you get and it will help with stability considering that toyota trucks dont have a rear sway bar, and also just dont take turns super fast and youll be okay, my record for a corner is 90 lol but it was exchange going from beltway to the highway lol but i also have a tundra at stock height with a 1 1/8" rear sway bar, handles like its on rails and improved the ride as well
  12. Mar 14, 2011 at 1:53 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I haven't noticed a decrease in handling from stock. I know I have significantly decreased body roll.
  13. Mar 14, 2011 at 1:57 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    How large of lift are you going to put on?
  14. Mar 14, 2011 at 2:18 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    For starters, make sure you put on a suspension lift and not a body lift.
  15. Mar 14, 2011 at 2:56 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    My 1990 Bronco handled and rode far better than stock once I put on a full 4" suspension lift on it.
  16. Mar 14, 2011 at 3:13 PM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    You could also try wheel spacers to widen the stance and improve handling.
  17. Mar 14, 2011 at 3:16 PM
    pittim
    pittim mittip backwards
    Pink slider.
    You're raising the COG. Guess what happens to handling.
  18. Mar 14, 2011 at 4:17 PM
    chilow
    This will be a mild 2.5 or 3 inch left, nothing too crazy.
