Lift after rear spring TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redfox458, May 19, 2009.
  1. May 19, 2009 at 9:47 PM
    Redfox458
    Redfox458 [OP] Well-Known Member
    07 Tacoma TRD Sport Access Cab
    So I've got the rear leaf spring TSB on my 07 Access Cab. I was looking around for a lift kit that will give me about 3" of lift, and level the truck at the same time. And yes, I'm looking for a kit, instead of putting one together myself. I would like something to just bolt in, I hate messing with the trial and error type thing. Should I just buy front spacers to level the truck and say screw the whole lift idea?
    Does the RevTek part #426 (3" front 1 1/4" rear) help with this at all??
  2. May 19, 2009 at 10:04 PM
    mattb1968
    mattb1968 Member
    Monrovia, CA
    07 TRD off road
    Pioneer in dash navigation
    I was wondering if the TSB makes a difference as well. Anxious to hear what people say.
  3. May 19, 2009 at 10:06 PM
    Redfox458
    My truck definitely sits higher in the rear after the TSB. I was hoping it was going to settle, but it hasn't yet. I could just level the truck, but then I'm jealous when I see another lifted 2nd gen :mad:
  4. May 19, 2009 at 10:08 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Ive got a brand new pair of OME 884 coils for sale. PM me if interested.
  5. May 19, 2009 at 10:09 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    My TSB raise my 4 banger up HUGE amounts. I'm talking about the rear being over 3" higher. However they will settle down, and adding some weight to the bed for a few weeks will speed that up.
    Spacers in the front will ruin your ride quality, and wear out suspension components quicker. That said, I am selling a readylift leveling kit :)
  6. May 19, 2009 at 10:11 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I got the rear tsb done. Then i bought the ome setup up front. I bought it preassymbled. It was an easy bolt on setup. My truck sits almostly perfectly level withought me touching the rear.
  7. May 19, 2009 at 10:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  8. May 19, 2009 at 10:28 PM
    Redfox458
    Hmmmmm I'm gonna have to go measure and see what the difference is between the front and rear of my truck. I think replacement front coils would be best now that you've brought up the ride quality/front spacer issue. OME 883s vs. 884s....just height difference (1/2"), or is there also a ride quality difference??
  9. May 19, 2009 at 10:30 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    I have a access cab and just got my tsb done as well. I measure it out and if I get bilstein 5100s and set them at 2.5" my truck will be perfectly level. Yours shouldn't be much different. If my rear settles over time then I will just put in a AAL to raise the rear back up so the front isnt higher.
  10. May 19, 2009 at 10:43 PM
    Redfox458
    Interesting. So I'm a bilstein idiot. I can get the adjustable 5100s, keep the stock spring setup, and almost perfectly level the truck? Wont this make the ride a little stiffer up front?
  11. May 19, 2009 at 10:53 PM
    Redfox458
    Oh, and I just measured the wheel gaps on my truck (yes, in the dark...I couldn't wait). I have a 6" front tire to fender clearance and a 9" rear tire to finder clearance.
    So either the OME 883/884 springs, or the bilstein 5100s to level the height of the truck....and the bilstein website says I can then clear a 33" tire? SWEET!
    Now to decide if I'm gonna mount a winch and winch bumper up front.....
  12. May 19, 2009 at 11:50 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    make sure you read up on the lift and running 33's. You will more than likely rub tires in the front on a 3" lift. spacers are cheap, billy's and/or new springs in front are better or you can go a full coilover for probly the best performance. do your research and buy stuff once, instead of kicking yourself later. good luck
  13. May 19, 2009 at 11:55 PM
    Redfox458
    So you think that the 5100s in front, set at 2.5" I'll rub a bit huh? Maybe I should look into some 32s? I don't really want to shell out more cash for upper control arms either. I'm guessing the 5100s and/or the OME springs are my best bet?
  14. May 20, 2009 at 8:47 AM
    cbcs1987
    Cody
    East Tennessee
    Yes you will rub. Theres a guy here I talked to about the same thing a month or so back. Roxspin is his name I think. He has 5100s at 2.5 with 33's and is rubbing. Even people with a full 3" lift are rubbin 33's. Either way if you want 33s youll have to trim.
    And yes, the 5100s at 2.5 will be stiffer than stock. Hope this helps
  15. May 20, 2009 at 8:55 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i have 3" CO's and i run the frame at the cab w/ 33's. i have the AP front bumper, so i dont have any issues at the front of the fenders but u'll have to trim there on a stock bumper, remove the flaps, and possibly rub the frame depending on the BS of the rim and tire size
  16. May 20, 2009 at 8:59 AM
    okietaco
    okietaco Member
    Oklahoma
    09 DB LB TRD SPORT
    Hey - just put in front Bilsteen 5100s set at 2.5 inches with Toytech 2 inch AAL (not same as TSB ~ .5 inch) and put on BFG KO 33's. :)
    RUBBING A-arm - so added 2.5 front wheel spacers and took off front mud flaps.:(
    STILL RUBBING some areas of black plastic in wheel well.:(
    Took razor to these areas and now RUB FREE with 33's!:)
    I'll try a post some pics today or tomorrow.
  17. May 20, 2009 at 11:51 AM
    Redfox458
    Well, I'm pretty lazy, hate doing something and taking it apart, hoping it will work, then taking it apart again. Maybe I'll just put on some 32s. Only an inch difference, I'm sure it'll look ok and at least less of a chance of rubbing.
  18. May 20, 2009 at 11:59 AM
    The_Hodge
    SC
    u can run a 32" tire stock...so no issues w/ rubbing or anything after a lift
  19. May 20, 2009 at 12:11 PM
    Redfox458
    Ok thanks, I'm horrible at the whole metric tire conversion math thing. If somebody were to ask me what size tires I have on now, I'd have to look at the tire. :confused:
  20. May 20, 2009 at 12:19 PM
    okietaco
    okietaco Member
    Oklahoma
    09 DB LB TRD SPORT
    Before I changed my tires my OEM tires DID NOT rub with my level - see my thread above.
