Lift Alignment Specs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 11, 2009.
  1. Feb 11, 2009 at 5:40 AM
    ballon78
    ballon78 [OP] Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    I thought i saw posted on a lift company vendor site or on here that a lifted truck should have different alignment spec when you bring it into get aligned....anyone seen them??? Even with new UCA's the alignment should be set a bit different than stock, correct??
  2. Feb 11, 2009 at 5:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your alignment should look like this:
    Toe: 0*
    Caster: 0*
    Camber: 2.4* to 3.1*
    zerotimeouts likes this.
  3. Feb 18, 2010 at 6:05 AM
    Gossamer
    Gossamer Howard Roark
    West of Illinois and East of Nebraska
    Hey Chris...after I had my 3" OME lift, the local shop did my alignment and set everything here...
    Left Right
    Camber= 0.7 0.5
    Caster= 1.2 1.4
    Toe= .01 .02
    Am i going to have issues with this? The camber seems pretty far off from where you are saying it should be. Quite frankly, I trust you more so if it's going to be an issue, I'll have them reset some of it.
  4. Feb 18, 2010 at 6:22 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
  5. Feb 18, 2010 at 6:24 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    x2
  6. Feb 18, 2010 at 6:46 AM
    Gossamer
    Just talked with my aligment guy and he said that he didn't feel comfortable increase the caster any more as it would negatively affect the camber again. Maybe he doesn't want to change it...I don't know. This is a pretty reputable shop and I don't think these guys are lazy or lying to me. Thoughts on the impact this could have if I leave it the way it is?
  7. Feb 18, 2010 at 6:47 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    is there a big difference between 2.1 caster setting and 2.4?
  8. Feb 18, 2010 at 6:49 AM
    Gossamer
    I would imagine not...but my caster is at 1.2 and 1.4...so I'm not sure if that is a huge difference or not. The truck tracks fine and there aren't any noticable issues with driving.:confused:
  9. Feb 18, 2010 at 6:52 AM
    Simon2150
    Austin, TX
    is the reason to have caster lower on driver side to compensate for road crowning?
  10. Feb 18, 2010 at 7:33 AM
    novakills
    novakills Well-Known Member
    Scott
    Tampa FL
    2010 Prerunner TRD Sport
    TRD CAI, debadged, TRD exhaust, bed d-ring mod, rubber bed mat, 6000K Bi-xenon headlights, 3000K HID foglights, Redline Tuning QuickLIFT PLUS Hood Struts, 2" Toytec AAL w/Bilstein 5100s, 1" aluminum tapered leaf spring spacer, Eibach 1.6" lift coils on Bilstein 5100s set at .85 with Light Racing UCAs, 10% tinted windows, 285/70/17 Toyo Open Country A/T, Pioneer MVH-X560BT,TRD Supercharger, Grillcraft Black MX upper and lower grill, RAAMmat Sound Deadening, Hybrid Audio Technologies Imagine Series I61-2 in rear doors, Hybrid Audio Technolgies Legatia L6 and L1V2 in front doors running through Hybrid Audio Legatia L2X crossovers, JL Audio 13TW5 in a bedlined Mr. Marv enclosure, Zed Audio Leviathan Amp on a bedlined Mr. Marv amp rack, DTLT Exhaust Headers w/O2 simulators, full LED lighting interior and exterior, OEM roof racks
    what about when you're in the fast (left) lane of a split four lane highway?
  11. Feb 18, 2010 at 7:44 AM
    novakills
    Scott
    Tampa FL
    LOL. I would definately be bothered if my truck wanted to fall off the crown TOWARD oncoming traffic. I'm at 0*Toe 0*Camber and 2.4* Caster on both sides so my truck drives straight on level surfaces. If I'm on a road with enough crown to necessitate different alignment specs I will drive to correct it. Although, I'm going to try a little more caster (2.6*) to dial in my return to center and a bit of camber as my tires seem to wear more on the outside than on the inside.
  12. Mar 16, 2010 at 12:54 PM
    kulitxplod
    kulitxplod Well-Known Member
    Middle TN
    2010 DC PreRunner
    I've got 5100s all around and they are set at 1.75 in front. My alignment numbers look like yours and after two alignments, the shop is telling me that they got it as near Camber 0, Toe 0, Caster 2.1 2.4 as possible. But my caster is still around your 1.2 and 1.4.
    Here are my numbers:
    Toe: .05 .03
    Camber: .7 .4
    Caster: 1.5 1.8
    Any thoughts? Anybody?
  13. Mar 16, 2010 at 2:58 PM
    kulitxplod
    Middle TN
    2010 DC PreRunner
    So there are no experts who have suggestions? Does anyone know for a fact that with stock UCAs and 1.75 set on 5100s these ideal numbers posted are possible?
  14. Mar 16, 2010 at 3:33 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    Does anyone know what the alignment specs would be with a 6" Fabtech lift kit? I was told that it would follow the factory specs since its DB...?
  15. Mar 16, 2010 at 4:08 PM
    choptop
    choptop MolĹŤn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Not possible, to get ideal specs with that lift install a set of Light Racing UCAs and it'll be good after a fresh alignment.
  16. Mar 16, 2010 at 4:13 PM
    kulitxplod
    Middle TN
    2010 DC PreRunner
    Gotcha. So .85 is the highest possible setting that is still able to get the proper alignment specifications, without UCA replacement that is?
    If the truck is no longer wandering, besides uneven wear, any other side effects?
  17. Mar 17, 2010 at 5:44 AM
    kulitxplod
    Middle TN
    2010 DC PreRunner
    It's not wandering anymore, I'm not sure what the first set of alignment numbers were, but whatever they were, the truck wandered after the 1.75" up front. I just concerned with the amount of camber.
  18. Mar 17, 2010 at 7:04 AM
    kulitxplod
    Middle TN
    2010 DC PreRunner
    So this is the word? It's not possible to get Toe 0, Camber 0, Caster 2.1 or more with stock UCAs when 5100s set at 1.75 in front?
  19. Mar 17, 2010 at 3:52 PM
    choptop
    Scott
    Austin, TX
    2014 4Runner TEP
    Toe can almost always be set close to 0 unless there is suspension/ steering component damage. Camber at 0 and caster at 2.1 or better is pretty much not possible at 1.75 lift with stock UCAs. Alignment can be correctly adjusted and considered "in spec" at 1.75 with stock UCAs but cannot be adjusted to "ideal" settings. This doesn't mean the truck will wander (mine doesn't with stock UCAs at that lift height except on roads with a very pronounced crown) but you may achieve a significant performance increase in cornering ability and steering wheel return to center with aftermarket UCAs and "ideal" alignment specs.
  20. Mar 17, 2010 at 4:01 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i'm saving for some UCA's. i couldnt get perfect specs..but the truck drives fine. it feels different, but cant put my finger on it. no wandering, just different.
