Lift and Level! How much am I looking at?
Discussion in 'Suspension' started by Moving4ward, Nov 14, 2012.
  1. Nov 14, 2012 at 10:42 AM
    Moving4ward
    Moving4ward [OP] Active Member
    New Jersey
    2011 2.7L 5-speed Taco 4x4
    Toolbox. Looking for wheels&tires!!
    2011 4-cyl 4WD
    How cheaply can I lift and level her?
    I've been reading through this sub-forum the past few days and haven't been able to really narrow it down.
    Having no prior knowledge of suspension, all of the different options are somewhat overwhelming (Although some of the stickies are super helpful).
    Ideally, I'd like to take the front up ~3" (more if i can afford it)
    and level the back (guessing 1.5" since I've read on here the rear sits 1.5 higher)
    For your time: (not mine)
  2. Nov 14, 2012 at 4:03 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    how cheap? well you get what you pay for. spacers and blocks would prolly be the cheapest, but your ride quality will be worse than stock and its not recommended for many reasons.
    so do you want to do srs offroading or mostly on-road with occasional excursions or is it strictly for mall crawling? you can look at my build thread for what I did. not the cheapest route, but not the most expensive one either. for something that is worth having tho id ballpark it at 3k depending on what you end up buying.
    anything over 3" is alot of $ and trouble to do on a taco.
    those girls are blocking my view of the truck btw! :rolleyes:
  3. Nov 14, 2012 at 4:04 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    I can tell you the answer you will get from every single person on here. Billys.
  4. Nov 14, 2012 at 4:11 PM
    Moving4ward
    New Jersey
    Makes sense, I've seen a lot about them on here.
    If I ordered the set, and went up 1" in the rear and 2.5" in the front, 1) would i need to modify anything? and 2) what kind of ride quality should i expect?
    I like to drive through pit but pretty rarely. And anytime i have in this thing, it's been super conservatively because it's a lease. So i guess you could say mostly mall-crawling.
    I honestly couldn't afford to come near $2k, let alone $3k, and am hoping to be able to do the install myself - both for the experience and so if i turn it in at the end of the lease i can quickly swap it back to stock.
    PS: I know what you're saying about those girls being in the way. Looks like a pretty sexy taco too, it's a shame.
  5. Nov 14, 2012 at 4:16 PM
    Aw9d
    Aw9d That one guy
    Az
    What truck??? :drool:
  6. Nov 14, 2012 at 4:29 PM
    mirraman
    mirraman Well-Known Member
    Tim
    Ventura
    98 4Runner Limited 4X4 e-locker :-)
    99 4Runner springs all around: 1" over factory.
    You could do billies up front for about $200 if you install yourself. If you want to keep the stock ride quality you should do Maxtrac 4" spindles and wheelers 3-piece add a leaf in the rear. Gonna run you closer to 1K and you need to be decent at turning a wrench, but worth it on both accounts. You will need longer shocks in the rear though. In the rear I run the 3-piece AALs, with overload spring, with adapted 5125s. I've run spacers before and they kinda suck. Right now I've got lift coils and they give a pretty stiff ride. I'm gonna switch to lift spindles and some billy 5100s when I have the $$$
  7. Nov 14, 2012 at 4:35 PM
    Moving4ward
    New Jersey
    So are you saying I couldn't just do the 5100s in the front and rear, and sit level at 2.5" up in the front and 1" up in the rear?
  8. Nov 14, 2012 at 4:35 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    well if its just a lease, I wouldnt do anything to it really.
    tires alone will be half your budget there, which I assume you will want, cause theres not much point in lifting without getting larger tires imo.
    but if your dead set on doing something, then your gonna be closer to 1.5-2" of lift up front, cause if you go much higher than that youll prolly need new uca's, which arent that cheap. prolly an AAL in the back tho.
    I dont have this setup but for ride quality everything ive read suggests its around stock, give or take. I suggest you look thru the build threads on here and find one thats close of what you want and ask them about it.
  9. Nov 14, 2012 at 4:36 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    hes a 4x4, you can only do spindle lifts on prerunners
    also op, to lift the back you have to do something to the leaf springs, like put another leaf in em or a block or something like that.
  10. Nov 14, 2012 at 9:10 PM
    Moving4ward
    New Jersey
    I'm definitely searching. I just can't find any good pics/info on just the 4 billie 5100s all the way up at 2.5 and 1.0, and nothing else modified.
    Why is that?
  11. Nov 14, 2012 at 9:13 PM
    Tuzzman
    Tuzzman Member
    Andrew
    Orange County, CA
    White TRD Sport 4x4
    Bilsteins 5100 @ 2.5 - front PlastiDipped badges Removed TRD stickers Weathertech Floor Liners PlastiDipped Wheel covers Matte Black Painted Skidplate Tinted Windows 15% Hitch Safe Nightshades on taillights HID Sylvania headlights Pop N Lock Tailgate handle Bak Roll-X bed cover Hi-Lift Jack Extreme
    I set the billies to 2.5 and did nothing to the rear. Sits just about level. Cost me about $450 for the billies, the labor, and for the alignment.
  12. Nov 14, 2012 at 9:21 PM
    scocar
    scocar Purity of essence
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Back to square one after the 2001. So...
  13. Nov 15, 2012 at 10:15 AM
    Moving4ward
    New Jersey
  14. Nov 15, 2012 at 12:41 PM
    mirraman
    Tim
    Ventura
    Didn't notice he was 4X4. Spindles are out. Although, if I remember correctly, there was someone designing lift spindles for 4X4s. Don't know if that ever came through, though.
    It looks like for economy purposes it'll have to be billies up front at 1.75" and 1" blocks in the rear. Should be pretty cheap.
  15. Nov 15, 2012 at 3:27 PM
    Moving4ward
    New Jersey
    How are 1" rear blocks better than 1" rear billsteins?
  16. Nov 15, 2012 at 3:49 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    You need to study a little more. Bilsteins in the back are only shocks. They cannot provide any lift. However, you must buy the right Bilstein shcok with the correct amount of travel for the lift you get. Otherwise, you can destroy the shocks if they top or bottom out.
    The rear can be lifted by one of three means: block, add-a-leaf, or new leaf pack. Choose this, then select a shock. If you are not sure on the shocks, Downsouth Motor Sports or Wheeler's Offroad can advise you.
    Blocks are cheap put provide sucky ride and will increase axle wrap. Add-a-leafs are a little more expensive, but if your rear leafs are already worn, they aren't recommended. New leaf pack is the best, and most expensive, quality lift you can get.
    You get what you pay for.
  17. Nov 15, 2012 at 3:51 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
