Lift and shock suggestions
Discussion in '5 Lug' started by norcal4banger, Feb 12, 2011.
  1. Feb 12, 2011 at 9:30 AM
    norcal4banger
    norcal4banger [OP] 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    I know theres threads already about lifts but I think if I just do the 2.5 or 2.75 coil spacers in the front I'll be good. I hate how my little truck looks front heavy. What do you think? Also, I am need of new shocks. Thinking ranch 5000s but wanted to see if there was anything out there better/cheaper?
  2. Feb 12, 2011 at 9:41 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Yes a spacer in front would level out your truck and make it looks nicer.
  3. Feb 12, 2011 at 10:16 AM
    norcal4banger
    Jack
    I just ordered 2.75" spacers for the front. Gonna do probably a 1" AAL next week.
  4. Feb 12, 2011 at 10:23 AM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    I would stay away from Rancho or any other white body shock (Superlift, Skyjacker, Procomp). Stiff ride, poor quality, prone to leaking and other issues with those. Good quality shocks such as Bilstein and OME are a good investment in my opinion.
  5. Feb 12, 2011 at 10:38 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    ^^^ what he said & Stay away from spacers ur truck will ride like shit
  6. Feb 12, 2011 at 11:16 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Thanks for the backup on the shock comment but I have to disagree with your spacer comment. I have 2.25 inch Ready Lift spacers on my truck and the ride is exactly the same as before. How can a spacer make a truck ride poorly when all it does is push the a arms further away from the fenders. It does not preload the coil or affect the coil or shock valving in any way. Are some of you having a negative experience with poorly made spacers? If I had to rate my Ready Lift spacer / factory Bilstien combo I would have to give it a solid 10 out of 10 for my daily driving use. I haven't had this truck off road yet though.
  7. Feb 12, 2011 at 1:50 PM
    norcal4banger
    Jack
    This is good to know...I'm kind of new to the lift thing. My last truck I just had paid a shop X amount of dollars for X amount of inches, and i'm wanting to do it myself on my taco but 705 can you explain what the differential drop is?
  8. Feb 12, 2011 at 2:10 PM
    Trifenix
    so cal
    99 LT 5 lug Taco
    You do not need a differential drop on your truck.
  9. Feb 13, 2011 at 7:08 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Thats right. The diff drop only applies to 4x4s. Its just a few hardware bits that lowers the front differential to slightly reduce the axle shaft angles. You dont have a front diff because you have a 2wd.
  10. Feb 13, 2011 at 7:16 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    With a top plate spacer, the ride may be the same, but forcing the whole assembly down binds your ball joints, and renders your bump stops useless. You will bottom out the shock before hitting the bump stops.
  11. Feb 13, 2011 at 12:14 PM
    705 Taco
    Dean
    2016 TRD OR AC
    Is that different than 5100's cranked to 2.5 inches? Or is that shock body longer? If it is longer it will still bind the ball joints. I ran a 2 inch spacer for 3 years with no issues. If I was wheeling it hard I'm sure I would feel the need for better shocks and springs.
  12. Feb 13, 2011 at 12:41 PM
    KPT
    09 Prerunner
    Very different. The 5100's preload the spring, similar to coil spacer, not a top plate spacer.
    What makes the 5100's better than a coil spacer is that the shocks are valved to dampen the stiffer spring load.
  13. Feb 14, 2011 at 6:27 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Ok. That makes sense. Guess ill put some miles on this setup and see how it goes. The coils and shocks are not that expensive so it would be a nice upgrade when I wear out these shocks.
