Lift and tire plans
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matmo215, Dec 8, 2016.
  1. Dec 8, 2016 at 7:46 PM
    Matmo215
    Matmo215 [OP] Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    i have a 2011 prerunner double cab and i want a 3" lift. As of now im looking to get the bilstein 5100s all around and up front set to 1.75. I will pair this with a 2" aal. Should i get new coils? Will it make any difference? My truck is at 98,xxx miles if that means anything, not sure if the coils have ever been replaced either as i got it at 95,xxx. Will i need new uca's or anything else?
    Now for tires. I love the KO2s no doubt, but i plan to stick with 16" rims. They only make the 265/75r16 in E load which is too thick of a tire. What are some other tire options not in E load that are rugged but great on road as this is my daily with little off-roading.
    Any help is appreciated thanks
  2. Dec 8, 2016 at 7:48 PM
    Pigpen
    Dan
    Northwest Montana
  3. Dec 8, 2016 at 7:54 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    You might as well get new coils if you can afford them. But they're definitely not needed.
    You'll need UCA's for anything above 2.5-3" of lift.
  4. Dec 8, 2016 at 7:55 PM
    Pigpen
    Dan
    Northwest Montana
    You can always do spindles like @ChadsPride Check out his build thread, it's very...uh...informative :rofl:
    MO Tacoma and DustStorm4x4 like this.
  5. Dec 8, 2016 at 7:56 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Any recommendations of UCA's? And do they have to be larger or the same?
  6. Dec 8, 2016 at 7:57 PM
    Pigpen
    Dan
    Northwest Montana
    SPC Light Racing (LR) UCAs for the win!
  7. Dec 8, 2016 at 7:57 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
  8. Dec 8, 2016 at 7:57 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'd get new OEM coils. They can be had for as little as $50 on this forum.
    You won't need anything else except an alignment. My first lift was 1.75 up front and a 2" 3 leaf progressive AAL and it was all under $500, it was an excellent setup for the money.
    To really have a noticeable upgrade from that, you're in the $750 range. The next step up is $1250.
    So depending on your budget you seem to be on the right track.
  9. Dec 8, 2016 at 7:57 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
  10. Dec 8, 2016 at 7:58 PM
    T4RFTMFW
    Sometimes, maybe.
    I'm on stock UCAs and have no alignment or tire wear issues.
    Pigpen and DustStorm4x4[QUOTED] like this.
  11. Dec 8, 2016 at 7:58 PM
    T4RFTMFW
    I'd recommend you buy those only if needed unless you have an extra $500.
  12. Dec 8, 2016 at 7:59 PM
    Pigpen
    Dan
    Northwest Montana
    LR UCAs are adjustable, the ball joint is greasable and replaceable, they have better down travel than any other UCA I know of...AAAAANNND (ready for it?) They're the least expensive of the trusted UCA options.
    RigginsTaco likes this.
