Lift And Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jongov, Nov 3, 2020.
  1. Nov 3, 2020 at 2:59 PM
    Jongov
    Jongov [OP] New Member
    What is the best tire/wheel setup on a 3” suspension lift? I’m not wanting to do any chopping on body modifications.
  2. Nov 3, 2020 at 3:13 PM
    AZ_J
    AZ_J Well-Known Member
    Ahwatukee, AZ
    2019 TRD OR 4x4 DCSB
    265/75r16, sliders, softopper, roof rack, 6112/5160's
    No chopping huh?
    265/75r16 stock wheel geometry
    255/85r16 stock wheel geometry
    CocaineAndCreatine and JoeCOVA like this.
  3. Nov 3, 2020 at 3:30 PM
    Wasatchrider
    Wasatchrider Well-Known Member
    That is stock he is getting a 3 inch lift
  4. Nov 3, 2020 at 3:43 PM
    Jongov
    I was thinking an 285/70/17 but I was wanting some info on if it’d run or not before I got them.
  5. Nov 3, 2020 at 4:00 PM
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    I've been researching wheels/tires over the past couple of weeks.... There's lots of existing information about 285/70-17 (or 285/75-16) in this and the Wheels & Tires forum.
  6. Nov 3, 2020 at 4:06 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    What is your intent? Overlanding, DD, Rock crawling
  7. Nov 3, 2020 at 5:25 PM
    Jongov
    I’ve had trouble getting a straight answer. Some say it won’t and some say it will. Even same setups have split answers
  8. Nov 3, 2020 at 6:02 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    A lift doesn’t arbitrarily help you fit larger tires, the issue has and remains to be tire width.
    The biggest factor in tire fitment is alignment, and wheel backspacing.
  9. Nov 3, 2020 at 8:05 PM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    I run 285/70/17 BFG KO2’s no rubbing without front mud flaps. I have SCS wheels 17x8.5 it’s really gonna come down the the wheels you run with the tires. I also did Camburg UCA’s.
  10. Nov 3, 2020 at 8:11 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Welcome and have fun searching the forum.
