Lift and Tires
Discussion in 'Wheels & Tires' started by Roronoa_Zoro, May 20, 2022.
  1. May 20, 2022 at 8:59 AM
    Roronoa_Zoro
    Roronoa_Zoro [OP] Member
    2016 Black Tacoma Base
    I got a 2016 base 4x4 2.7l. I want to throw a 2 in lift in the front and a 3 in the rear. I also want to run 270/70/r17 or a 265/75/r17. Has anyone done this setup or something similar? I don't want the truck to be supper doggy around down. Right now I have no lift and I'm running 265/65/R17.
  2. May 20, 2022 at 1:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Are you wanting to increase the rake for a reason? Your fine with the 265/75/17. Don’t believe anyone makes a 270/70/17.
    ToyoTaco25 likes this.
  3. May 20, 2022 at 1:57 PM
    Roronoa_Zoro
    I want a rake to it because I usually haul around a atv in my bed and a pull one behind me, and since I want to put a 2 in lift around my truck, I thought it would be a good idea to have a 1 in rake in the rear to keep the truck from sagging when I have a lot of weight in the bed or if I'm pulling something, that's why I would put a 3in block in the rear just to keep it a little higher in the back. And for the tire size I meant to say 275s, but I think I'm going to go with 265/70s.
  4. May 20, 2022 at 1:59 PM
    gotoman1969
    You have about 1” of rake from the factory. So if you go 2/3 you’ll end up with 2” of rake.
  5. May 20, 2022 at 2:02 PM
    Roronoa_Zoro
    Haven't been under it yet but there should be a 1 inch block right? If so then I would take it out and replace it with a 3 in block Or is the 1 in rake from the leaf springs?
  6. May 20, 2022 at 2:25 PM
    gotoman1969
    Nope from the factory there is no block in the rear.
