Lift Chatter
Discussion in '4 Cylinder' started by ToyotaHondaOwner, Nov 13, 2011.
  1. Nov 13, 2011 at 8:10 PM
    ToyotaHondaOwner
    ToyotaHondaOwner [OP] Member
    San Antonio
    2001 Toyota Tacoma
    Any suggestions I just bought a 2001 Taco with 115000 miles and now that it is getting cold I'm getting lifter chatter I've put in some Rislone treatment but that seemed to have little effect on this issue again suggestions?
  2. Nov 13, 2011 at 8:13 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    some people use Seafoam. maybe that will help
  3. Nov 13, 2011 at 8:18 PM
    TACOMABOSS
    96 SR5 4x4
    or its piston slap?
  4. Nov 13, 2011 at 8:42 PM
    ToyotaHondaOwner
    San Antonio
    2001 Toyota Tacoma
    Nah it's lifter chatter. It goes away after being run after a couple of minutes . . . .
  5. Nov 13, 2011 at 9:00 PM
    ToyotaHondaOwner
    San Antonio
    2001 Toyota Tacoma
  6. Nov 13, 2011 at 9:29 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    That could be the pistons as well because when the piston heats up it expands and it will get quite
  7. Nov 13, 2011 at 9:32 PM
    TACOMABOSS
    96 SR5 4x4
    my dad has piston slap on his car. its not a tacoma but its still an engine. and it goes away after its warmed up
  8. Nov 16, 2011 at 10:24 AM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    Have the valves ever been adjusted? It couldn't hurt.
  9. Dec 3, 2011 at 2:39 PM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    LOL , I realize there is a hint of sarcasm here
    but doesnt the 01 have shim and bucket so there are no "lifters" ?
    and shim and buckets just get quieter and tighter with wear
    most likely piston slap or it could be a loose mount rattling
  10. Dec 3, 2011 at 2:44 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I would remove that Rislone hydraulic lifter treatment and get some good quality viscuous synthetic in there like Rotella T-6 15w-40 or similar
  11. Dec 3, 2011 at 3:39 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    That's correct. No hydraulic lifters on a 2001. Most likely is piston slap, and most likely won't hurt anything since it abates after a couple minutes.
    My 1993 22RE did the same thing from day one, and so did a '76 Chevy with a 250 inline six. That one slapped for 22 years with no failures...
  12. Dec 6, 2011 at 2:29 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I switched to synthetic and put on a oil pan heater. I use the oil pan heater under 30F. No more tic, slap or what ever that noise is.
  13. Dec 8, 2011 at 8:49 AM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    i always start playing with different weight oils untill the motor quites down. Mines pretty quite on the recomended 5w40. But i recently had the lifter buckets/valve stems grinded down for proper shim clearance. It takes 15 minutes to pull valve cover and start checking clearances. I would check clearance once every 30k cuz its soo dang quick .
    If you just wanna check clearances here are the specs...
    2RZ/3RZ Valve Clearances: COLD
    Intake: .015-.025mm (.006-.010 in.)
    Exhaust: .025-.035mm (.010-.014 in.)
    Here's a detailed how to on it...
    http://www.yotatech.com/f128/5vz-fe-3rz-fe-2rz-fe-valve-adjustment-tech-226997/
