Lift Choices
Discussion in 'Suspension' started by JFKLives, Apr 18, 2011.
  1. Apr 18, 2011 at 9:48 AM
    JFKLives
    JFKLives [OP] Byte Me
    San Jose, CA
    2015 4x4 TRD Sport Extra Value W/JBL
    FJ Team Trail Red on Black Wheels P265/75R16 BF Goodrich Tire, color match front emblum, debadged and Fold-A-Cover G4 Elite
    This is not my first truck by any means but it will be my first lift. Have been doing a lot of reading on the subject here and elsewhere on the web but I'm not 100% sure I have everything down. Based on my research, I'm pretty set on a 6" lift and I've narrowed it down to the following three kits but I was hoping that someone that has experience with them could pipe in with their opinions of the pros and cons. Just about any insight would be appreciated
    Fabtech K7019 ~$1600
    • 6" Basic System
    • Use 315/70R17 tires w/ 17x8 wheels w/ 4 5/8" BS w/ minor trimming
    • 1 FTS26026BK Component Box 1
    • 1 FTS26007BK Componet Box 2
    • 1 FTS26010BK Spacer Box
    • 2 FTS7181 Performance Rear Shocks
    Pro Comp K5073B ~$1600
    • Lift Height: 6 Inches
    • Front Lift: Drop Crossmember,Strut Spacers & Steering Knuckles
    • Includes: Differential Drop Brackets, Sway Bar Drop Brackets
    • Rear Lift: Block/U-Bolt Kit with Add-A-Leafs
    • Shocks: Rear ES9000 Shocks
    • Shock Boots Included
    • Max Tire Size: 35X12.50
    • Wheel Size Range (Inches):18+Wheel Width Range (Inches):8-9
    • Min-Max Backspace (Inches)4.0-4.65
    Also, how much of a difference would the following kit be compared to the two listed above and is it really worth the additional thousand dollars?
    Pro Comp K5073BMX ~$2600
    • Front Lift: Drop Crossmember, Steering Knuckles & Coil Overs
    • Shocks: Rear MX6 Shocks
    • Shock Boots Not Included
