Lift Coils and Spacers????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeffman1991, Oct 11, 2008.
  1. Oct 11, 2008 at 7:59 PM
    Jeffman1991
    Jeffman1991 [OP] Active Member
    Jacksonville, Florida
    '08 Blue Pre-Runner TRD
    Standard Profile Black Toolbox, Straight Pipes with Borla Tips, Secondary air filter removal, K&N Air Filter, CB Radio with 4 foot whip, 50 watt PA, two 8 inch JL Subwoofers, Pioneer Headunit, Jensen 400 watt speakers all around. 3 inch lift coming soon.
    I want to lift my 08 Dbl Cab. I wanted to know if I could do the toytec ome lift springs and a 3 inch spacer getting 6 inches of lift. Im pretty sure you can't due to the CV angle but im just curious. I would go AAL and 3" Lift Blocks in the back
  2. Oct 11, 2008 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Stacking lifts is a bad idea. Your truck will have no down travel and will ride like a wagon. 3" blocks on the back is also a bad idea. If you want a 6" lift, then get dedicated 6" lift.
  3. Oct 11, 2008 at 9:12 PM
    Khaos
    Khaos Big Member
    Bryant
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    +1
  4. Oct 11, 2008 at 11:22 PM
    awymore997
    awymore997 Quitting is for Quitters
    Andrew
    Charlotte, NC
    08 Access Cab TRD OFRD 6 speed
    +2 x infinity. :eek::eek::eek:
  5. Oct 11, 2008 at 11:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Agree with the other peeps who've posted up above me, you gotta pay to play, do it right the first time and you won't regret it down the road.
  6. Oct 12, 2008 at 10:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've seen someone try that many years ago....
    Put lift coils in PLUS a spacer - and he broke the lower coil seat on the strut. The strut couldn't handle the amount of pressure.
    It's a bad idea....
  7. Oct 12, 2008 at 10:30 AM
    Jeffman1991
    Thanks thats what I figured, so inorder to get anything more than 3 inches would be to get a full suspension lift kit like the 6 inch one fabtech offers?
  8. Oct 12, 2008 at 10:45 AM
    Khaos
    Khaos Big Member
    Bryant
    You can get 4" Spindles, but those will run around $1K, and I'm not sure whose currently selling them.
    You can also get a body lift. Most members here (myself included) do not like body lifts.
    You can get adjustable coilovers (which are the best way to go) that you can adjust to give you lift. I think the new Toytec C/Os go up to 4" (Not sure, you can email them and ask) of lift. Coilovers up front give you the best ride and flex. They are also the easiest lift to install so you won't have to pay someone else to install them.
    For the rear, you can get a 3" leaf pack. That should run around $300 and will perform FAR better than rear blocks. New shocks will be required, but itll ride and flex better.
    Also, I know your wanting more than 3" lift. Keep in mind that when all is said and done, you will have more than 3" of lift all together when you add in tires. You can get a tall skinny tire like a 255/85/16 which will make your truck look taller.
    This truck has a 3" Toytec lift with 255/85/16. Look at all the ground clearence he has.
  9. Oct 12, 2008 at 1:14 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    +1. same here:)
