Lift compatability between model years
Discussion in '1st Gen. Tacomas (1995-2004)' started by Art, Sep 2, 2010.
  1. Sep 2, 2010 at 7:31 AM
    Art
    Art [OP] Member
    Art
    Southern Maine
    4x4 SR5
    2 inch body lift, 33in tires
    I have an opportunity to get a nice suspension lift off of a 95 Tacoma. I was wondering if it would be compatable with my 01 Tacoma. Any ideas?
    Oh, I did do a search for lift compatability and I could not find the answer. :)
  2. Sep 2, 2010 at 8:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The 95-2004 trucks have the same suspension setups.
    So, yes they are compatible.
    The only differences to look out for, are the engine & cab configuration. You might not end up with the amount of lift that you were planning on.
    For instance - If your truck is a regular cab and you buy coil springs or AAL's for a double cab..... the lift you'll get on your regular cab could be taller than what the lift is specified to give (on a double cab). Or the opposite end of the scale.
  3. Sep 2, 2010 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, the 98's had a different rear spring length than the earlier ones....
  4. Sep 2, 2010 at 8:31 AM
    Art
    Art [OP] Member
    Art
    Southern Maine
    4x4 SR5
    Good information.
    The lift is on a 4cyl access cab like mine.
    Basically its a front coil over kit on the front and in the back it has bilstein shocks.
    Thanks guys
