Lift cost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Georgiadeerslayer, Oct 3, 2020.
  1. Oct 3, 2020 at 11:03 PM
    Georgiadeerslayer
    Georgiadeerslayer [OP] Member
    Steven
    Black ltz hoe
    6.5" lift, C.A.I., Flowmaster, programer, A.F.m. deleted
    So guys, I am wanting to have my wifes 2008 Tacoma OR lifted w/ RC 4" ,for her birthday. What am I looking at in total cost on average?
  2. Oct 3, 2020 at 11:10 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    RC I'm assuming is Rough Country which is a block and spacer lift, as this is a kit I assume you have seen the price of the parts so I'm inferring you mean install cost.
    I would NOT go with the Rough Country lift, there's better out there for cheaper.
    Look into Bilstein 5100's and OME 887 coils with a progressive add a leaf for the rear, Headstrong Off-Road is a great place to get those parts.
    As for install doing it yourself is naturally free and it's not too difficult but I'm assuming you'ed rather have it installed, in that case it can very significantly by shop and market so hard to say really, I would expect to pay anywhere between $500-1000.
    Ryan2103a and Island Cruiser like this.
  3. Oct 3, 2020 at 11:13 PM
    Georgiadeerslayer
    Steven
    Black ltz hoe
    Thanks. Yea I really dont have the time to do it, with work. Ill check out these parts. I really appreciate it.
  4. Oct 4, 2020 at 12:39 AM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    I just did my suspensions and paid roughly $700 for a new set of eibach coilovers (equivalent to 5100), wulf aal, kyb top hats and an alignment. I did the labor myself which took a day.
  5. Oct 4, 2020 at 8:28 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    This looks to be a drop bracket lift which personally, should be avoided. These type of lifts require cutting the crossmember which would be difficult to reverse if you change your mind. Better off sticking with a 3" CO setup with rear progressive 3 aal or whole leaf pack. Call Headstrong Offroad as suggested.
