lift decision, gurus beat it up before purchase
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dr dave, Dec 14, 2013.
  1. Jan 3, 2014 at 11:45 AM
    N.GA Taco x3
    N.GA Taco x3 Well-Known Member
    Kevin
    Georgia
    11 Pre DC Sport- 02 Pre DC OR- 12 DCSB 4x4
    For a small cheap lift for tame off road and mostly highway, I did the daystar front 1.25 in. poly top plate spacer and 1 in. Billet alum. rear block. I can tell no difference at all in the way it drives vs stock. Completely satisfied and it looks great. Parts total about $100.
  2. Jan 3, 2014 at 2:58 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    I have had AAL and Dakars on my truck. I found the AAL to be a nice ride. The Dakars are definitely a little stiffer on the road. Personally, I found my coil spacers and AAL set up to have a very nice on road ride. Even my mom commented on how well the truck rode. Then I went and tore all that off and put on foxes since I ended up taking it off road a fair bit.
    That said, your original plan looks like it will probably meet your expectations... with the exception of the rear block in the back. I would go AAL.
  3. Jan 3, 2014 at 3:29 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    If "under $1200" is your goal, you can def. get better lifts than spacers and blocks. Like others have said an AAL is better for the rear (for you and passengers). if you set bilsteins at 2.5 up front, you still will have to get different uca's most likely. Even though it's just for looks, cheaper isnt always best. I'm not totally hating on spacers/blocks, i had them once, and that 1 time was all i needed to realize i never wanted them again. Maybe you will like them, just not my cup of tea. To each their own.
