lift delema
Discussion in 'Suspension' started by crewdog, Apr 10, 2011.
  1. Apr 10, 2011 at 7:57 AM
    crewdog
    crewdog [OP] Active Member
    mike
    chicago illinois
    2005 tacoma
    K&N induction, Borla catback,885's & Dakkars grillecraft BLH
    looking to lift my 05 taco and I was given 2 options
    - a ICON adj coil over and 1" rear springs I could run 33/11.5 on 8" wheels with 5" backspacing. Anything I need to worry about like tire rubbing,extending brake lines etc?
    - RCD 4-5" system
    besides price whats my best option
  2. Apr 10, 2011 at 12:06 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    First off, those two options couldn't be further away from each other on their purpose.
    Are you going for looks (RCD), or offroad performance (Icon)?
    There are plenty of other options out there as well, less expensive ones as well.....
    5" BS is cutting is close, but with some trimming and a cab mount chop they should fit.
    you would need extendedbrake lines with the RCD, but not with the icons.
  3. Apr 12, 2011 at 4:27 PM
    crewdog
    mike
    chicago illinois
    2005 tacoma
    looking for performance over looks. Heard ICON's are a good coil over. what would be cheaper options
  4. Apr 12, 2011 at 9:03 PM
    KPT
    09 Prerunner
    If you are going for performance, not looks, then DO NOT get the RCD. It will actually lower your ground clearance in comparison to your stock truck.
    If you are looking for adjustable coilovers, pretty much anything is cheaper than icon. Look at Toytec, Radflo, etc.
  5. Apr 14, 2011 at 6:36 PM
    crewdog
    mike
    chicago illinois
    2005 tacoma
    pretty handy with a wrench done lifts on older striaght axles before so probably do the work myself. Are UCA's a must with the coil overs and what did you do on the rear? I'm looking to get 33" tires underneath
  6. Apr 14, 2011 at 7:20 PM
    KPT
    09 Prerunner
    Uca's usually are needed if you go over 2.5". An add a leaf for the rear is the way to go
  7. Apr 14, 2011 at 7:26 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Don't forget longer shocks in the rear
