Lift Doesn’t Provide Tire Clearance - Someone Explain This Dummy Style
Discussion in '3rd Gen. Tacomas (2016-2023)' started by erok81, Sep 29, 2022.
  1. Sep 30, 2022 at 5:55 PM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Oh boy.....
  2. Sep 30, 2022 at 5:58 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    So you say 2" lift helps you fit 33s but then go on to say that a 2" lift doesnt help and you need body modifications instead. :rofl:
    CaptainBart45 and hiPSI like this.
  3. Sep 30, 2022 at 5:59 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    It’s not your explanation, you are not understanding how the lift actually works. In your diagram and explanation you are overlooking that the lowest point the wheel can travel to is identical between stock suspension and after lift. Look at your diagram and imagine both drawings with the exact same lowest point the wheel can travel to.
    Spacer lift can works similar to how you have explained, but we are not talking about spacer lifts.
  4. Sep 30, 2022 at 7:31 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    ok I summarize what I wrote for ya since you didn’t understand lol.
    Person A
    If you want to ride around on street at ride height no off-roading 2inch lift with good alignment will fit according to what “fit” means for person A.
    Person B
    wants to Offroad truck and use all suspension possible. 2inch lift plus body modification is necessary so no a 2inch lift alone for this person would not fit according to what “fit” means for person B.
    Now op are you person A or B? Frankly I think op is trolling since I e seen him in LT thread a bit lol
    BottleShark likes this.
  5. Sep 30, 2022 at 7:50 PM
    BottleShark
    BottleShark Well-Known Member
    TJ
    Bullard, Tx
    2018 White TRD Offroad Long Bed
    2" lift, AAL Rear, Front bumper, 12k Winch
    I’m not talking about any one vehicle. Yes, some vehicles A arms can only travel down so far. My point is, if the A arm downwards travel isn’t inhibited by binding, hitting frame, ball joint travel, ext then the A arm will be limited by the travel from the strut. If the strut has, let’s say, 6” of travel and that give spindle 10" of travel then you will have that 10” no matter where the top of the strut is mounted. I’m not saying this it Tacoma specific but in general. I don’t know if I’m missing something or y’all are not getting my point.
    The location of the top strut mount does not change travel UNLESS the down travel is limited by something. So a puck lift wouldn’t effect the ride UNLESS it causes binding.
    Some vehicles with large wheel wells, a lift CAN allow bigger tires. On vehicles like the Tacoma, there are other aspects that effect tire size. Like body mounts and wheel well size.
  6. Sep 30, 2022 at 9:06 PM
    JoeCOVA
    Joe
    Colorado Springs
    LOL its the same suspension geometry (i.e. factory), lift makes no difference. You can run a 35" tire with no lift.
    The reason a basic lift doesn't provide tire clearance is 3 simple words...independent front suspension.
    one again, thats incorrect
  7. Oct 1, 2022 at 6:45 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    :bored:
