LIFT DONE
Discussion in 'Suspension' started by busatodd, Mar 17, 2017.
  1. Apr 5, 2017 at 10:47 AM
    #81
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Thank you. I guess I'm not worried about a couple hundred miles then with a barely noticeable vibration. My wife says I'm crazy but I know it's thereo_O
  2. Apr 6, 2017 at 4:30 AM
    #82
    Sweetleu417
    Sweetleu417 Member
    2019 TRD OFF ROAD 6speed manual
    I did the 2inch leveling on the front. Noticed the viberation in the gas pedal and could hear something coming from the front end. Installed the new ecgs ptfe bushing and problem was solved. There it's to much play with the needle bearing. The bushing closes up the tolerance
  3. Apr 6, 2017 at 5:04 AM
    #83
    busatodd
    busatodd [OP] BUSATODD
    whiteland
    2016 limited mgm
    3rd gen 5100 bilstiens set at 0 with ome 888s, LR UCA, 5160 bilstiens in back with icon 3 leaf aal with 1" block. Fuel savage wheel wrapped in nitto ridge grapplers 285/70/17
    How hard was it to do?
  4. Apr 6, 2017 at 5:16 AM
    #84
    ievko82
    WV
    Is the bushing ptfe? I thought it was oil impregnated bronze. Just interested, I'm getting ready to order mine.
  5. Apr 6, 2017 at 5:23 AM
    #85
    Sandeman
    Sandeman Well-Known Member
    Home of the Headless Horseman, NY
    '17 TRDOR, '04 GX470
    im gonna pass on reading 5 pages of this and go on a whim and say youll need a ECGS for the drivers axle... IF it hasn't been mentioned already
    Sweetleu417 likes this.
  6. Apr 6, 2017 at 5:36 AM
    #86
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I agree with others. I had an extremely faint vibe at low speeds sometimes. I replaced the needle bearing with the ECGS bushing and got instant gratification. Truck rides smoother than ever.
  7. Apr 6, 2017 at 7:33 AM
    #87
    Sweetleu417
    Sweetleu417 Member
    It has a ptfe coating. I've called ecgs and they said it should last the life of the vehicle
  8. Apr 6, 2017 at 7:37 AM
    #88
    Sweetleu417
    Sweetleu417 Member
    Wasn't to bad. Have a bearing puller on hand to remove the needle bearing. I don't remember the steps of doing it. Was last year sometime but I have 7,000 miles on that bushing now with no problems
  9. Apr 6, 2017 at 7:40 AM
    #89
    ievko82
    WV
    How long did you have the vibration for before replacing it?
  10. Apr 6, 2017 at 10:04 AM
    #90
    Sweetleu417
    Sweetleu417 Member
    I would guess 1-2 thousand miles. Then I got annoyed and looked further into it
  11. Apr 6, 2017 at 10:11 AM
    #91
    ievko82
    WV
    No noticeable damage from running it like that? I have to replace mine and haven't ordered it yet.
  12. Apr 6, 2017 at 12:04 PM
    #92
    Sweetleu417
    Sweetleu417 Member
    There was slight wear on the end of the shaft. Nothing major just glad I got it done before say the needle bearing were to go or wore the shaft more
  13. Apr 6, 2017 at 1:51 PM
    #93
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
