Lift + firestone air bags w/ daystar cradles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Choco_Truck, Dec 30, 2020.
  1. Dec 30, 2020 at 10:18 AM
    Choco_Truck
    Choco_Truck [OP] Active Member
    Haven't been able to find any details so I figure it's time to ask to forum directly. Has anyone had issues running Firestone airbags with daystar cradles on a lifted Tacoma? I've seen non-lifted applications and obviously there's no problems. Wondering if I'll run into issues on this type of air setup on a modified rear end. For reference, I'll be running Deaver J66s, about 1-1.5 inch lift in the rear. Thanks in advance, TW!
  2. Dec 30, 2020 at 10:22 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I've been running Ride-Rites with Daystars on OME Dakars since 2012 with no issues. Be sure to plumb the air-bags separately.
    Thegenerik1 likes this.
  3. Dec 30, 2020 at 11:24 AM
    griffee
    griffee Well-Known Member
    No issues. Running Dakar leaf packs, Daystar cradles. I think it is a nice system. Since the bottom of the bags are no longer attached to the axle, they float. No chance of putting a lot of stress on the bag when the suspension unloads.
  4. Dec 30, 2020 at 12:54 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    The daystar cradles really need some lift to work right as-is.
    On my (unlifted) rear-end truck, there is 'insufficient' uptravel due to the cradle thickness.
    I am going to make a new cradle mount to lower them down some if I ever get around to it...
    Mikeybuck and Thegenerik1 like this.
  5. Dec 30, 2020 at 12:56 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    J66s and air bags seems a strange combo. J66s are for designed for minimal weight desert trucks. Air bags are for stabilizing lots of weight. What are your intended uses for the truck?
  6. Dec 30, 2020 at 12:59 PM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    I agree 100%. I removed my air bags from my stock truck cause of the ride. I'll put them back once i lift the truck.
    BigWhiteTRD[QUOTED] likes this.
  7. Dec 31, 2020 at 2:39 PM
    Choco_Truck
    Thanks for all the feedback everyone. I appreciate it.
    @hoarder23 - I like the small amount of lift as well as the flex that J66s provide. I don't plan on adding any permanent weight in the rear aside from a low profile tonneau cover. The air bags are there to provide a cushy ride, address the taco lean, and level out the rear on the one or two days a year I am carrying a heavy load (camp, hauling large objects, etc.)
    Drainbung likes this.
  8. Dec 31, 2020 at 3:14 PM
    hoarder23
    Shay
    NJ
    Scratches
    Have you seen this thread https://www.tacomaworld.com/threads/avoid-deavers-j66.331776/
    The J66s will be overloaded by the tonneau cover, especially with the double cab. The U402 Stage 1 would probably be a better option for you. Worry less about the amount of lift and pay more attention to how you will actually use your truck. You fill the bed up for a camping trip you will be riding on the bump stops.
