Lift for my Taco?
Discussion in 'Suspension' started by KRich, May 12, 2010.
  1. May 12, 2010 at 10:07 AM
    KRich
    KRich [OP] Well-Known Member
    BC, Canada
    07 Black DCSB TRD Sport 4x4
    Hi all,
    I'm a noob to the whole lifting of your truck and everything that goes along with it. I would like to do a modest lift that would let me put a bit bigger tires on the truck and make it look a little more aggressive but not dramatically affect gas mileage and vehicle handling. 90% of my driving is in the city so I do not want anything dramatic. I am curious about the approximate cost to get this done at a shop. I have heard of toytec and revtek lifts, is there a best option out there? Can I keep my stock trd rims and put bigger tires on them? Does anyone know of a good place to get the work done in the Vancouver, BC area?
    Thanks for your help!
  2. May 12, 2010 at 11:39 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    SEARCH! :D
    But 5100s with 33s seems to be a popular/efficient lift, I like it.
  3. May 12, 2010 at 11:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Start out by reading this, which is stickied at the top of the suspension forum.
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
    then you can go onto this, which is an ongoing list of prices paid for a lift install (which is also stickied at the top of the suspension forum)
    http://www.tacomaworld.com/forum/suspension/11590-ongoing-lift-install-price-thread.html
    You will need wheel spacers to run anything over 265's on your stock rims. All of these answers and more can be found with a simple search.
  4. May 12, 2010 at 12:51 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    The kit comes with a Life Time warranty also! :)
  5. May 12, 2010 at 1:32 PM
    KRich
    BC, Canada
    Darrick,
    Do you have a distributor/dealer in Vancouver, BC, Canada region? Also, what kind of install time would be reasonable for a shop to install the ultimate kit? (I think I have the TSB rear leafs). Thanks!
  6. May 12, 2010 at 1:34 PM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    Mmmmmmmmmmmmmm, I want it soooo bad.
  7. May 12, 2010 at 1:40 PM
    Toytec Lifts
    Rocky Mountains
    PM sent.
    Install time should be 4-6 hours.
  8. May 12, 2010 at 1:52 PM
    KPT
    09 Prerunner
    Just so you know, the lift that Darrick suggested is pretty Top of the Line as far as 3 inch lifts go. There are way less expensive options that Toytec offers if you want to sacrifice a little quality and adjustability.
    Not trying to step on anyone's toes, just noting that you said in your original post that you wanted a modest lift and nothing drastic. Fully adjustable coilovers and four new shocks does not fit in that category.
  9. May 12, 2010 at 3:12 PM
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    Get a set of Bilstein 5100 adjustable struts for the front, reuse stock coils and throw an add a leaf in the rear. Total investment including alignment, less then 500 dollars with good ride quality and all the components are straight bolt on that you can do yourself. You'll end up with a little less then a 3 inch lift. Just my two cents...
  10. May 27, 2010 at 7:54 PM
    KRich
    BC, Canada
    Do i need a diff drop kit or anything else? Also, should I get an AAL that is set up to work with the 4 leaf TSB style (canadian truck)? I heard that there was a toytec one that is made for tacos with the rear TSB?
  11. May 28, 2010 at 4:15 AM
    KPT
    09 Prerunner
    That depends. Are you are 4x4? Your profile doesn't say.
    If you already have the 4 leaf pack, then definately get the AAL designed for trucks with the TSB.
  12. May 28, 2010 at 10:48 AM
    subspd
    subspd King of used Toyota trucks
    Cumming, GA
    06' 4Runner Limited 4x4 V6
    Lift, lights, light saber..
    Where can you buy this setup?
  13. May 28, 2010 at 10:56 AM
    KRich
    BC, Canada
    My truck is a 4x4 so do i need to do anything with the diff? I was looking at your build and was wondering if I could get away with just adding the 5100s in the front set to 1.75 for now and do the rest later. Would this even out the truck with the rear 4 leaf pack. I measured and at the wheel wells, the back is sitting about 2" higher at the moment.
    I could then adjust the 5100s in the front to 2.5", do the AAL in the back and/or replace the rear shocks with 5100s when i am looking at getting new tires?
  14. May 29, 2010 at 2:11 AM
    Reaper10
    Brandon
    The 5100 adjustable shocks are available from any number of online retailers, a lot of folks use down south motors who is a vendor here on the forums. The AAL I used, I got from ToyTec, which is also a vendor here. Just be prepared to wait a bit for the front shocks they seem to be backordered pretty often. Hope this helps.
  15. May 30, 2010 at 2:40 PM
    KRich
    BC, Canada
    Hey Reaper10, did you put in a diff spacer in the front to go with the bilsteins?
  16. May 30, 2010 at 5:14 PM
    Reaper10
    Brandon
    Nope, no diff drop or anything, just the bilsteins. My alignment is still within spec but the truck does feel a little floaty at highway speeds so my next addition is going to be a set of Light Racing upper control arms. From everything I've read here and elsewhere the upper control arms should take care of it. I think the need for after market upper control arms varies greatly from truck to truck with any lift less then 3 inches. Some people like me feel the need for them but many others do not.
  17. Jun 1, 2010 at 6:23 AM
    Toytec Lifts
    Rocky Mountains
    We recommend the use of the diff drop once you reach over ~2 inches of lift.
    Yes you should get the TSB AAL because our standard AAL won't fit the pack.
    Yap, right here: http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72
  18. Jun 2, 2010 at 2:31 PM
    KRich
    BC, Canada
    Darrick,
    So the tsb aal that you linked to will add 1 1/2" to the current rear end height right?
    cheers,
    Kyle
  19. Jun 2, 2010 at 5:07 PM
    Austin82
    Austin82 Active Member
  20. Jun 3, 2010 at 2:33 PM
    Toytec Lifts
    Rocky Mountains
    Yes, if you have the stock leaf pack from Toyota, the TSB AAL will return you 1.5" of rear lift.
