Lift for street
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mikez104, May 31, 2021.
  1. May 31, 2021 at 5:47 PM
    mikez104
    mikez104 [OP] Active Member
    I've been reading thread after thread and am still confused. I love the look of 33s with a 3" lift. I don't do offroading with this truck. I use it as the daily driver and haul a trailer with my quad and my dirtbike to the trails on the weekend.
    Looking for some advice for a lift that will level out the truck and make 33s fit easier. Also don't want to cause undue wear on the driveline as when I haul the toys to the trails, I have about an hour ride each way on the highway @75+mph. Any advice?
  2. May 31, 2021 at 5:50 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    All depends how much you want to spend. 5100s with stock springs plus an AAL in the back would probably check all your boxes for relatively cheap. You'll need a CMC for 285s, though. Axle shims and/or carrier bearing drop should alleviate most/all driveline vibes.
    Junkhead and GillyLink like this.
  3. May 31, 2021 at 5:53 PM
    mikez104
    As cheap as possible. It won't be going offroad. I know what 5100s are but not an "AAL". And it's a gen 3 if that matters.
  4. May 31, 2021 at 5:56 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Aal. Add a leaf. You put an extra leaf spring or two into you stock leaf pack.
  5. May 31, 2021 at 5:58 PM
    mikez104
    Thanks!
  6. May 31, 2021 at 6:00 PM
    pahaf
    paul
    NorCal
    You want the cheapest option? Get a spacer lift. Will ride not that great…..but the spacer lift is about $150 for front and back. Or cheaper if you can find a used one on Craigslist.
    My first lift for the Tacoma was a 3” front and 2” rear spacer lift that I got for $60 off Craigslist and it worked for the first 3-5 months before I upgraded my truck
  7. May 31, 2021 at 6:03 PM
    mikez104
    When you say "not that great", can you expand on that?
  8. May 31, 2021 at 6:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Changes the suspension operating angles in "not a great way"
    It'll ride stiff
    The bumpstops wont protect anything if it bottoms out really hard, you can bend/damage the lower shock body
    If you can appreciate the way a Tacoma feels and handles, do it the right way and get proper coilovers.
    I bought the entry level Icon setup and have been really happy with it for the past 5 yrs. Its set around 2-2.5 inches in front, leaf pack in the rear.
    The way it's valved makes it nice and tight in the corners (good for street driving) and loosens up over bumps/washboards off pavement
    Chew likes this.
  9. May 31, 2021 at 6:14 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    Eibach pro truck stage 1. Put a small block in the rear. Eibach also sells that.
  10. May 31, 2021 at 6:21 PM
    Bishop84
    Bishop84 Well-Known Member
    TRD4X4TOY likes this.
  11. May 31, 2021 at 6:21 PM
    old_and_in_the_way
    old_and_in_the_way Well-Known Member
    Somewhere hot, flat and brown.
    Most honest TW user and best thread title ever. Love it.
    mikez104[QUOTED][OP] likes this.
  12. May 31, 2021 at 6:22 PM
    mikez104
  13. May 31, 2021 at 6:29 PM
    Foster1
    California
    2023 SR V6 4x4
    Sterling_vH111 likes this.
  14. May 31, 2021 at 6:32 PM
    mikez104
    Ha! It's funny how many Jeeps I see around here that are jacked to the moon and never have/will see even a dirt road.
  15. May 31, 2021 at 6:32 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Hope you're prepared for the 4 mpg drop.
  16. May 31, 2021 at 6:35 PM
    mikez104
    That's fine. I threw the 265/75/16s on there and noticed a small drop and I guess a bit more won't matter.
    OMGitsme[QUOTED] likes this.
  17. May 31, 2021 at 6:35 PM
    Sinagua
    Sinagua Beerdom Brewing - brewing in the shadows
    Rob
    Harrisburg, NC
    2019 OR DCSB, 2022 Accord Sport Hybrid
    Dobinsons Suspension, SOS sliders and slimline bumper, Smittybilt winch, Skinny Geolanders and a tune
    You can run pizza cutters/skinny 33” 255/85/16
    Foster1 likes this.
  18. May 31, 2021 at 6:55 PM
    mikez104
    Do the pizza cutters require the CMC? I just looked that up and :/. Some say it's not too bad. Maybe just get a few beers in me and...
  19. May 31, 2021 at 6:59 PM
    TacoedBars
    TacoedBars TacoedBars
    Sacramento
    16 TRD 4x4 OR
    If you don't mind rubbing all the time then no need to go and get a CMC :sawzall:
  20. May 31, 2021 at 7:03 PM
    mikez104
    What I don't get is how some folks say they rub and others are like nope, no rubbing. You'd think they either do or don't.
