lift front 2.5", need diff drop?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wncjim, Nov 4, 2014.
  1. Nov 4, 2014 at 4:50 PM
    wncjim
    wncjim [OP] Active Member
    Western NC
    How much front lift is possible without diff drop?
    I plan to order bilstein 5100's. I see they offer 3 settings, 0", 1.25", and 2.5". I'd like to avoid the diff drop.
  2. Nov 4, 2014 at 5:03 PM
    T4coma
    T4coma Active Member
    Mass
    2003 XtraCab 4x4 v6 TRD SR5
    5100/5125 shocks, grey wire mod, deck plate
    Shouldn't need one. In fact, you'll most likely only get about 2" out of them with your stock springs if your over 100k. I'm at 160k and my stock springs and bilsteins on the 2.5" setting only netted me about 1.75"
  3. Nov 5, 2014 at 4:56 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    When I bought the 5100's for my 98 the increments listed were .85", 1.75" and 2.5", but I have seen both settings described.
  4. Nov 6, 2014 at 5:03 PM
    wncjim
    Western NC
    Ok, I see that I will not get 2" front lift from the bilstein's alone. The rear is 2.5" higher than the front, it looks bad. I am about to order the front bilsteins from toytec, if I need a little more can I add the 1/4" top spacers to level out my truck?
