LIFT GURU's....HELP PLEASE>>>
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04TrDeeZ, Oct 24, 2010.
  1. Oct 24, 2010 at 8:09 AM
    04TrDeeZ
    04TrDeeZ [OP] Member
    Don
    DFW
    04 TRD Prerunner SR5
    Stock
    So I've been doing lift kit searches for the last 3 weeks and I have no idea on what to get. I wheel little to none at all and I mainly drive my taco on the weekends. What I'm looking at is getting a 3" lift. I would like to clear 33's, but 32's and 31's are my first choice. I do haul my duck boat around a lot during duck season other than that its pretty much for looks. I would like to spend about 500. Thanks
    stock 04 pre runner
  2. Oct 24, 2010 at 8:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Look into an Old Man Emu set up. Its about the best for the buck you can find. Also, Check out the 5100's for the front and rear. They can use the stock coil spring, and preload the spring to achieve the desired height (up to 2.5"). Any 2.5 to 3 inch lift is going to require new UCA's to get the alignment in check, and fitting 33's will require some trimming.
  3. Oct 24, 2010 at 9:02 AM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    X2, OME and some new UCA's FTW. My tacoma is also my DD and I havent noticed a major drop in gas mileage even with my ARB bumper and winch on.
  4. Oct 24, 2010 at 9:32 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    ...then IMO, OME is not what you are looking for necessarily. If it's just for looks, then throw some spacers in the front and AAL in the rear. No point in spending money for nicer parts if they won't be used wheeling
  5. Oct 24, 2010 at 9:34 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    If your budget is $500ish and this is just for looks, OME for sure.
    No one should ever buy spacers. For anything. Ever. I just cannot see a situation where they're a good call unless you MUST HAVE THE LIFT RIGHT NOW and are broke as shit.
  6. Oct 24, 2010 at 10:36 AM
    STLharry
    Harry
    VT
    Front OME cost me like 430 for the parts...what about lifting the rear of his truck?
  7. Oct 24, 2010 at 10:40 AM
    jandrews
    AAL are about 80 bucks. Rear OME are pretty inexpensive as well.
  8. Oct 24, 2010 at 12:23 PM
    04TrDeeZ
    Don
    DFW
    Stock
    Thanks for the response guys keep them coming. Maybe I should save up and wait to get the toytec Ultimate lift or run the 5100's all the way around.
  9. Oct 24, 2010 at 12:52 PM
    pittim
    pittim mittip backwards
    Pink slider.
    if your leafs are flat, you're going to want to get new springs.
    right there you're at your $500.
  10. Oct 24, 2010 at 10:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    IMO a budget of $500 to lift your truck is very unrealistic. I cannot recommend any of the cheap spacer lifts either.
    If your rear springs are in good shape (questionable on an '03), billies all the way around with an AAL in the rear will be the cheapest. Even then, by the time all is said and done, it'll cost you more than $500.
  11. Oct 24, 2010 at 10:42 PM
    MadTaco461
    MadTaco461 BRO runner
    Murrieta, CA
    99 turbo 5 lug long travel
    Kinda stock
    x2 on getting the 33's to fit. They'll fit but need a bit of trimming.
  12. Oct 25, 2010 at 5:43 PM
    04TrDeeZ
    Don
    DFW
    Stock
    Well guys thanks for all the reply, but I think it will be best to wait for a little more cash on hand to get a better lift kit.
  13. Oct 25, 2010 at 5:45 PM
    pittim
    Pink slider.
    wait til you have around $2200 saved up, then go with a full OME kit from wheelers, AND do tires at the same time.
    3in lift with stock tires looks retarded.
  14. Oct 25, 2010 at 5:58 PM
    04TrDeeZ
    Don
    DFW
    Stock
    I have Eagle wheels on 32's sitting in the shed now. LOL I'm also considering 5100's on all 4 and AAL just to cure my urge for a bit while.
  15. Oct 25, 2010 at 6:02 PM
    tt07
    tt07 Well-Known Member
    north carolina
    01 4wd
    none yet
    IMO lifting a prerunner is a waste of money!!!! But its yours
  16. Oct 25, 2010 at 6:02 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Which OME springs will give 3"? Just the 882s? I'd like 3" without the harsh ride of the 882s (i have no extra weight from a bumper or anything) Is there another OME option for 3" besides adding the spacer to 881s?
  17. Oct 25, 2010 at 6:40 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i'd just go with 5100's all around which will run u about 300 bucks for those and an AAL pack. Just set the front to 2.5" and u can still get ur alignment pretty good w/o new UCA's
  18. Oct 27, 2010 at 9:30 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Why doesnt ARB have spring heights and rates listed on their site? So many dealer sites have conflicting information about ome springs.
  19. Oct 27, 2010 at 9:33 AM
    pittim
    Pink slider.
  20. Oct 27, 2010 at 9:38 AM
    coltonp91491
    coltonp91491 Member
    colton
    Sylva,NC
    GET BIG! 04 Tacoma doublecab 12" lift 37's
    6" fabtech lift, 3" ruff country coil spacers and shackles, 3" preformance accesories body lift, 37x13.50 nitto mud grapplers, 5%tint, 7" touchscreen, 2 15"kicker cvr's, 4000watt boss audio amp, and streetglow lightstrike underglow
    go to local toyota dealer and get 3 inches installed for $600 with warranty
