Lift height and bumper suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SethQuigg, May 20, 2019.
  1. May 20, 2019 at 5:36 PM
    SethQuigg
    SethQuigg [OP] Member
    Seth
    2018 Tacoma TRD
    Nothing but wanting to learn what to do! Considering lift / suspension / larger tires.
    Whats up Team!
    Just bought a new Tacoma and am looking for advice regarding a potential lift / suspension / and larger tires.
    Couple questions: For a functional lift do you recommend a 3" , 4" or 6" ? Pros and Cons? I will be pulling a small trailer. Probably weights 1000 lbs.
    -Who makes a solid bumper? Ive checked out the ARB Summit. Looks pretty solid. Thoughts?
    Thanks everyone. I appreciate your input.
    SQ
    Bigdaddy4760 and Hobbs like this.
  2. May 20, 2019 at 6:17 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    Bigdaddy4760, tcjacado and Hobbs like this.
  3. May 20, 2019 at 6:23 PM
    SethQuigg
    Seth
    2018 Tacoma TRD
    Thanks!
  4. May 20, 2019 at 6:25 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    Anything bigger than 3" require an ifs relocation kits and potentially new spindles as well so its a big increase in cost over 3".
    I think the frame also needs to be cut, someone can correct me on this. But that'll void your warranty 100%.
    Your 2018 will need to have the collision detection system readjusted by the dealer no matter what you do cause the detection angle changes.
    You will feel a loss of power for any tires size increase above 32", try to keep the tire weight light. Your options to fix this are to change the gear ratio, 4.88 is common for auto's. People seem to say it feels stock again up to 33". Above 33" you will want 5.29's.
    If your towing i suggest a gear change if your going up in tire size. It will reduce gear hunting immensely.
    tcBob likes this.
  5. May 20, 2019 at 6:26 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    tcjacado likes this.
  6. May 20, 2019 at 6:28 PM
    Tacoma1845
    Tacoma1845 Well-Known Member
    Anthony
    Central Virginia
    2018 Tacoma TRD Sport DCLB (Inferno- Premium/Tech)
    Welcome!
  7. May 20, 2019 at 6:28 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome, check out the vendor section as well as the suspension sections of the forum. Go read and read some more. Also take a look at the towing section.
  8. May 20, 2019 at 6:29 PM
    SethQuigg
    Seth
    2018 Tacoma TRD
    Hey thanks a lot. Sounds like you think its not really necessary to do the lift then. Appreciate your input!!!!
  9. May 20, 2019 at 6:29 PM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    Functional? Leave it stock height with some high end suspension and 265's.
    SethQuigg[OP] and tcjacado like this.
  10. May 20, 2019 at 6:33 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
    Its not, ive been through 18" ish deep river in a bone stock off-road and got through just fine. Find some good tires for the stuff you do 90% of the time and spend money on recovery equipment for the other 10%.
    A 2" Old man Emu lift with upgraded front springs for the bumper would be enough for 60-75% of the guys who ask the same question you did. Alot of the 40-25% it isn't good enough for, need it for desert running or want something shiny on their rig to show off.
    Clearwater Bill likes this.
  11. May 20, 2019 at 6:38 PM
    SethQuigg
    Seth
    2018 Tacoma TRD
    What tires do you recommend?
  12. May 20, 2019 at 6:43 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
    The big thing is weight. Initially i had cooper stt pros on mine, cause I loved the snow performance but they ended up being too heavy. If I had been able to keep my truck i would have upgraded to 4.88 gears and it probably would have been fine.
    I recently got some skinny wrangler duratracs for my wifes 4runner and have been very happy with them. They look meaty but aren't overly wide and the off road performance has been great. Not awesome in mud, but snow and trails have been good. Bonus is they're light and even though the skinnys are 2" taller than stock, they cost the same as duratracs in stock size, and are only 1lb or 2 heavier. What size are your rims 16"?
  13. May 20, 2019 at 6:49 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
  14. May 20, 2019 at 7:15 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
