Lift help for my 4 bannger
Discussion in 'Suspension' started by Gus 524, Jan 21, 2013.
  1. Jan 21, 2013 at 6:00 PM
    Gus 524
    Gus 524 [OP] Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    I'm going to be purchasing a 3in lift kit for my 2009 4 cylinder 4x4 access cab tacoma. I have done a tiny amount of research and found this lift in my price range. http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72 I was hoping to get some opinions on it. Also there are options for either a 2in or 1.5in rear leaf spring. I was wondering what one would give me the most level lift? (don't care for bro lean much) One more thing is do i need a diff drop?
    Thanks,
    Justin
  2. Jan 23, 2013 at 4:13 PM
    Gus 524
    Justin
    MN
  3. Jan 23, 2013 at 4:25 PM
    bzzr2
    bzzr2 Well-Known Member
    the rear shocks are gonna be stock length, so they will top out easily, make noise and be less than perfect. the front coils are going to ride a bit stiff on the 4cyl, not sure what will happen if you are looking to set coil mount at .85 setting... or leave at stock setting wth coils and a top plate spacer will give you better travel and ride.. that is my 2 cents. i went OME... for an extra $100 or so you can do that, leave out the OME rear shocks and go procomp for an extra 1.75 inches of rear down travel... i guess thats my 5 cents... either way you will be happy. hopefully somebody with the setup you are looking at will offer some helpful insight.
  4. Jan 23, 2013 at 7:39 PM
    Gus 524
    Justin
    MN
    Thanks for your reply. That gives me a lot more to think about. Acually gives me to much to think about lol. Thanks again man.
  5. Jan 23, 2013 at 7:40 PM
    Gus 524
    Justin
    MN
    Anyone else? Would like to hear from somebody who has that set up. Bump
  6. Feb 19, 2013 at 7:27 AM
    Gus 524
    Justin
    MN
  7. Feb 19, 2013 at 11:17 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    buy a used 5lug set of leafs. they will give 1.5-1.75" of lift without the crappy AAL ride. theres a set for sale here for cheaper than a AAL
  8. Feb 21, 2013 at 7:29 AM
    Gus 524
    Justin
    MN
    Might be a dumb question but do I add the 5lug leads to my leads I have now?
  9. Feb 21, 2013 at 7:40 AM
    disc0monkey
  10. Feb 21, 2013 at 1:08 PM
    Gus 524
    Justin
    MN
  11. Feb 21, 2013 at 1:49 PM
    disc0monkey
    no shit AAL ride, less wandering on bumpy turns, proper flex, longer life.
  12. Feb 23, 2013 at 10:58 PM
    Gus 524
    Justin
    MN
    Ok thanks for the info.
