Lift Help; Got a Quote on Pro Comp Lift + 285s Today
Discussion in '3rd Gen. Tacomas (2016-2023)' started by m00nLambo, Oct 5, 2020.
  1. Oct 5, 2020 at 7:24 PM
    m00nLambo
    m00nLambo [OP] Member
    2018 Tacoma SR5 | Midnight Black
    I just bought a 2018 SR5, 4WD, V6, 7k miles.
    I visited a shop in Raleigh/Triangle area today. They recommended 1” rear, 3” front leveling kit by Pro Comp. I want to run 33” tires so they suggested a 1.25” wheel spacer. For tires, they recommended 285/70/17 Toyo ATs. They suggested not doing an add-a-leaf kit since the backend is so light.
    1/3 lift kit: $280
    Rear block kits: $212
    Tires: $780
    Wheel Spacers: $200
    Alignment: $141
    Labor: $600
    Total: $2414 after tax
    What I’ll use it for: working on my land which isn’t too rough, carrying stuff, and looking pretty. No rock crawling.
    Questions:
    What do you guys think about this type of lift? I had a 2000 4Runner that I lifted with adjustable coil overs and new shocks back in the day. I want something that’s comfortable to drive everyday and durable.
    Also, with a 1/3, do you guys think the truck will look unbalanced with the front too high? I tend to like the ‘raked’ look but the guy at the shop didn’t recommend doing more than 1” on the rears.
    Finally, any insight on the prices they’re quoting or the amount of labor involved?
  2. Oct 5, 2020 at 10:34 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    U do a 3/1 lift ur likely to end up nose high. Why not consider doing the work urself? Plenty of how to videos on youtube. A floor jack a couple jack stands a basic wrenches and sockets are all thats needed. Even if u have to purchase a couple tools it will cheaper than paying labor to install
  3. Oct 6, 2020 at 1:47 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You will be nose high with that lift. I recommend 2” front and 1.5” rear. Research is great. Good luck
    VaToy likes this.
  4. Oct 6, 2020 at 7:57 AM
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    You will be nose high if you actually get 3" in the front, but not by much, it won't be instantly noticeable unless you have OCD about it.
    - If they are selling a 3/1 lift kit, that means 3" in front and 1" in back, I see you listed the blocks separately which means they are adding another set of blocks? the 3/1 kit is supposed to include that. Double check.
    - With that size tire, you have a couple of problems, if you dont lift you will rub on the wheel wells/cab mount. If you lift 3" you might rub on the UCAs so then you put spacers and you're back to rubbing on your wheel wells. It's not an exact science, depends a lot on exactly how much lift you actually get, the tire width ("285" is supposed to be the width but it varies) and how wide the spacers you get are.
    - We get alignments done for $75 all day every day... $141 is high, and I'm in San Diego, nothing is cheap here.
    -Prices for Tires and Labor seem reasonable for all those parts installed.
    Dirk Diggler likes this.
  5. Oct 6, 2020 at 7:59 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    If you use the truck like a truck and load it up it will be nose high for sure.
    FreshMexicanTaco likes this.
  6. Oct 6, 2020 at 7:59 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Why are they charging you for a rear block kit and also for a 3/1 kit?
    Alignment is about double the price.
    I'd do the lift yourself in a garage and get a higher quality lift if you are comfortable spending that money already.
    71tattooguy likes this.
  7. Oct 6, 2020 at 8:01 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome aboard!
  8. Oct 6, 2020 at 8:03 AM
    FreshMexicanTaco
    AJ
    San Diego
    Also, a set of Bilstein 5100s would be about what they are charging you for blocks so you may want to consider that instead.
  9. Oct 6, 2020 at 8:15 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Great advice. I started off with a spacer lift. Learned from members on here , picked a better set up in the long run. Imo for me Great step up 5100’s , 6112 or eibach can’t go wrong.
    Good luck OP
  10. Oct 6, 2020 at 10:00 AM
    m00nLambo
    I’m really worried about being nose high. I like the aggressive raked look. Nothing worse imho than trucks with a saggy rear.
    As far as doing the work myself, I could try, but I’d be buying all of the tools. I don’t have anything. I also don’t want to screw up.
  11. Oct 6, 2020 at 10:01 AM
    m00nLambo
    With a 2/1.5, can you clear 285/70/17 (32.8”) tires or do they rub really bad. I don’t want to do any cutting.
  12. Oct 6, 2020 at 10:06 AM
    m00nLambo
    UCAs are a concern to me now especially since the shop didn’t mention them. If I did a 2” front, would I be able to clear the tires?
  13. Oct 6, 2020 at 10:06 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    It’s going to rub. 265/75/16 won’t rub. To run a 285 at that lift height you will most likely need cmc and control arms to get more caster to push tire forward. Lots of threads on this topic. I personally am running 265/75/16 on 2” front and rear is 1.5” aal. Imo still looks good but others will disagree
  14. Oct 6, 2020 at 10:06 AM
    m00nLambo
    Good point! I need to figure that out.
  15. Oct 6, 2020 at 10:08 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Also I’m planning on spc control arms just to get better handling my 2cents
  16. Oct 6, 2020 at 10:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    So you don't really 'need' a lift, you just want one.
    Certainly that's ok, but obviously you don't want to just make it a photo queen either.
    Find another shop, get more estimates.
    This one is recommending high margin low to modest quality stuff.
  17. Oct 6, 2020 at 11:47 AM
    m00nLambo
    100%. I like the look. And given the fact that I wont be doing any offroading other than driving on my own property (~10 acres in central NC, no mountains or crazy terrain), I want something that doesnt destroy ride quality on roads. I definitely don't need long travel.
  18. Oct 6, 2020 at 11:48 AM
    m00nLambo
    Thank you! Excited to rejoin the yota community. Former owner of a 2000 4Runner Ltd w/3" lift and 1973 Land Cruiser FJ40.
  19. Oct 6, 2020 at 11:53 AM
    FreshMexicanTaco
    AJ
    San Diego
    No, its not easy to get those tires to clear, If you do just a 2" lift in front and change your tires to just a little bit taller (265/75/16) youll end up with a good looking truck that performs well and doesnt break the bank or cause problems.
    Get a set of front bilstein 5100s, 265/75/16 tires and just level off your truck. it will cost you about 1200 depending on the tires you get.
    whatstcp and 71tattooguy like this.
  20. Oct 6, 2020 at 1:26 PM
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    It can come down to the wheel you choose to go with and the offset of the wheel. Trd Pro wheels in both the tacoma version and the 4runner version seem to have the least chance of rubbing with the 285's. Stock wheels will usually need wheel spacers to allows 285's but using more than a 3/4" spacer could cause some rubbing from what Ive seen.
