Lift Help Needed
Discussion in 'Suspension' started by ryantaco, Apr 30, 2013.
  1. Apr 30, 2013 at 9:22 AM
    ryantaco
    ryantaco [OP] Well-Known Member
    SoCal
    06 DC Long Bed TRD Sport
    I recently got my first tacoma(2nd gen) and I plan on off roading about 10 to 25% of the time, but nothing too serious just some fun trails and messing around in the sand a little bit; I would also like to put about a 2.5- 3inch lift on it
    With that being said, what are your recomendations on what I should do and please explain what they are such as bilstein ect. and their effects (sorry for the ignorance this will be my first very own tacoma) or would my tacoma still look nice with just a leveler and what exactly is a leveler.( i have been researching this but I usually only come across post that say what the lift is not to much explanation bc most all ready know what they are talking about)---Thanks
  2. Apr 30, 2013 at 9:25 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Dont get a spacer lift, you dont even need to know what it is or does just know its no good if you wheel.
    that being said. 5100s are adjustable and will give you 2.5" of lift if you crank them up. They are a low end coilover but that doesnt mean they are bad.
    OME is a good setup using another coilover and they are generally more durable.
    Mid travel is a whole nother story and LT is too far for what you want.
    A leveling kit does just that, usually it involves spacers but you can also level your truck with 5100s.
    What else?
    Edit: although, if you want a lot of fun in the sand run LT, just be prepared to spend $10000 lol
  3. Apr 30, 2013 at 9:27 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    first............................
    do u have 5 or 6 lugs on ur rims?
  4. Apr 30, 2013 at 5:01 PM
    ryantaco
    SoCal
    I believe they are 5
    Another quick question: is there a difference between the TRD off road lugs and TRD sport lugs
  5. Apr 30, 2013 at 5:04 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    If you have a 4x4 or a prerunner you have 6 lug wheels. and I do not believe the lugs are any different from offroad to sport? correct me if I am wrong somebody.
    The wheels themselves are different however.
  6. Apr 30, 2013 at 5:10 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    offroad and sport are both 6 lug, as are all 2nd gen 4x4 and prerunners regardless of sport/base/offroad.
    All prerunners are based off the 4wd chassis and suspension and have 6 lugs.
  7. Apr 30, 2013 at 5:48 PM
    ryantaco
    SoCal
    Then I that case I have 6
  8. Apr 30, 2013 at 5:53 PM
    Monster Coma
    Corey
    Then here is your answer
  9. Apr 30, 2013 at 6:07 PM
    mdkingen
    mdkingen Hang on, I saw this done in a cartoon once!
    Las Vegas
    2012 Tacoma
    I have an Old Man Emu 3 in.(Probably closer to 2 1/2 in.) 884 springs and no spacers. Toytech 2 in. add a leaf in the back. You can research lifts on her until your head spins. I think the general consensus on here about spacers is that they are not worth it. Find the sticky on the home page about lifts and read through it. It has a lot of good info. Then, do what you need to do.
  10. Apr 30, 2013 at 8:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Excellent question Brock !!
    If you're a "5 lugger" you'll be happy to know that you do not have to chop any cab mounts to fit slightly larger tire as the TRD/Sport models do, this is because there are no cab mounts TO chop....
  11. Apr 30, 2013 at 11:07 PM
    ryantaco
    SoCal
    With the lift what would be an appropriate tire size?
  12. May 1, 2013 at 1:52 AM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    With a 3" lift? Prob some 32-ish unless you wanna cut and trim. Check out some other people's builds in the builds forum to get some solid for sure fits.
