Lift help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco2zday, May 22, 2023.
  1. May 22, 2023 at 5:43 PM
    Taco2zday
    Taco2zday [OP] Well-Known Member
    Ben
    2018 Tacoma trd off-road 4x4
    I have a 2022 sr5 long bed and wanting to lift it. Things I do know I want is to do 2 1/2 inch front lift and 2 inch in the back and I’m planning on running 285 tire and I’m going to be running a leer bed cap. I just would like some suggestions on what I need to achieve that while running a bed cap. I know I want to run Deaver leafs in the back just not sure which model and I know I want a good shock setup with upper control arms. Just so much info out there and not sure if anyone is running a settup like this!
  2. May 23, 2023 at 8:49 AM
    stav
    stav Active Member
    Mikey
    Illinois
    22' Toyota Tacoma Limited Nightshade
    OEM TRD Lift Kit, Grille, Intake Exhaust, Shift Knob
    With my experience because I have 285 tires, they will definitely rub on the OEM/Factory upper control arms (I've still yet to buy spacers), so that is a cause for concern there but you did say you were looking for different control arms so that may be your fix right there. I am running the OEM TRD Lift kit, and it has worked very well for me, yet it does seem a little "too" level for my taste, as I feel trucks like these deserve just a lil' bit of rake, but that is ultimately up to personal preference.
  3. May 23, 2023 at 8:53 AM
    Tucker2020!
    Tucker2020! Well-Known Member
    My truck was lifted on 5100s w/ Eibach's, ICON RXT at option 3 and FN Fivestar wheels (wrapped with 285/75-16 Coopers) for almost 5 years. The rest were stock. Aside from rubbing on the mudflaps at full lock, going in reverse, no other rubbing issues
  4. May 23, 2023 at 8:57 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
  5. May 23, 2023 at 12:34 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
