lift help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coalminer, Sep 5, 2011.
  1. Sep 5, 2011 at 12:36 PM
    coalminer
    coalminer [OP] Well-Known Member
    ky
    tacoma
    dry flow drop in filter
    so i want to lift my truck 3''. im not an off roader but from time to time i go hunting and some of the roads are washed out. these are old gas well roads so there not to bad. i hear strut extentions are a bad idea. can someone tell me why this is or would they be fine for what i do.
    thanks to all who reply.
  2. Sep 5, 2011 at 12:38 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They are a bad idea because at full droop they overextend your ball joints, causing them to bind.
    Strut extensions also make your bump stops useless, you will bottom out the shock before you hit the bump stops.
  3. Sep 5, 2011 at 12:47 PM
    coalminer
    ky
    tacoma
    thank you for the info. no one ever told me why so thanks
  4. Sep 5, 2011 at 1:30 PM
    XPOTRPR
    XPOTRPR #safetydevelopment
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    CHECK BUILD
    Pro comp full 3" suspension lift. $470. That's what I'm running. no issues. No complaints.
