Lift help/questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by starver, Nov 27, 2018.
  1. Nov 27, 2018 at 9:36 AM
    starver
    starver [OP] Member
    2018 Tacoma TRD Offroad
    I want to purchase the Bilstein 5100 front and rear shock set. The new shocks will add up to 2" of lift to the front, and 1" to the rear.
    If I set them to the max (2", & 1") will I be able to add 17" wheels/tires. Currently the truck has 16" wheels/tires. It's a 2018 TRD offroad double cab.
    I do drive it offroad in some pretty aggressive areas. So the lift isn't really for looks, I'd like to have a little more clearance for rocks - without much modification. Which is why I went with shocks.
    I've never messed with the suspension on any vehicle, any help/advice would be appreciated.
  2. Nov 27, 2018 at 9:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Some Tacomas come with 17" wheels, so that's not an issue. The issue is what kind of wheel it is and it's specs of width, offset, etc. And what size tire you expect to run.
    Both of those factors have much more to do with clearance than any 'lift'. And a suspension lift does not raise the low points of the axle lines. Only tires do that.
    You can run 255 80 17s (full 33") on OE wheels with no lift at all.
    Running the springs preloaded by using the high perch on the 5100's will likely give an undesirable ride quality. You're better to lift with using the proper spring and keep the low perch setting.
    BTW, there is a suspension forum and a wheels/tires forum that might be helpful to peruse.
    tcBob and WSW3 like this.
  3. Nov 27, 2018 at 9:47 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome to TW
  4. Nov 27, 2018 at 9:51 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Take a look on the suspension forum.
    Don't lift by pre-loading the shock, get different springs if you are going for lift. The rear shocks will not do anything for lifting the truck, an add-a-leaf or leaf pack will.
    17" wheels will fit without an issue. Be careful with tire size and wheel specs, because you want to avoid rubbing. I have 885s and 5100s in the front and 255/80 R17's on stock alloy wheels and they rub a little on one side at full lock.
    CoastieRon and ChadsPride like this.
  5. Nov 27, 2018 at 10:10 AM
    starver
    starver [OP] Member
    Thanks for the advice everyone. I'll check out the suspension forum.
  6. Nov 27, 2018 at 10:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    I think that can be solved by going to the OE T4R wheels.......... pinch of offset difference.
  7. Nov 27, 2018 at 10:19 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    I've been looking around for real cheap used ones for about a year now. No luck yet. Don't want to spend money on wheels that are going to get all scratched up anyway.
