Lift help TSB trying to level out truck
Discussion in 'Suspension' started by CRONKED TaCo, Mar 17, 2013.
  1. Mar 17, 2013 at 2:00 PM
    CRONKED TaCo
    CRONKED TaCo [OP] Well-Known Member
    Robbie
    Alabama
    Silver 2011 sport dbl cab 4x4
    Wet Okoles, Satoshi grill, Hella 700's hid converted, Alpine audio install, sound deadened, limo tint, 4.7 Tundra TRD Catback, 3 inch procomp, bed lights. To come TRD supercharger, roof racks, stuffing 285 70 17 trail grapplers.
    Hey guys i have the rear tsb and was wondering if I should use a two inch lift block or a one inch. If i use the one inch block i will be exactly level, but if i use the two inch block i will get the rake i want. So my question is will i have to use longer brake lines with a two inch block and tsb?
  2. Mar 17, 2013 at 2:07 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Are you going to take it off roading? Why do you want to add a block? They provide horrible road manners and are bad for the springs. Why not just get a AAL?
    No I wouldn't say you need longer brake lines.
  3. Mar 17, 2013 at 6:22 PM
    CRONKED TaCo
    Robbie
    Alabama
    Ok so a two inch add a leaf would work?
  4. Mar 17, 2013 at 7:11 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Absolutely. There might even be a 1.5" if you'd like
  5. Mar 17, 2013 at 7:16 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Yep toytec sells a 1.5" AAL for TSB leaf packs
  6. Mar 17, 2013 at 7:59 PM
    des0011
    des0011 New Member
    Utah
    TRD Off Road 4x4
    Linex ARB Deluxe Warn M8000 KC Hilites Ventshades Pop & Lock Manual N Fab Nerf Bars CBI TrailRider 2.0 5100's in the Front Fox 2.0's in the Rear with an AAL Husky Liners Soon to Be More...
    I'm wanting to do a 2" leveling kit on my truck. Any issues that anyone knows of with that. I plan on using the skyjacker kit.
  7. Mar 17, 2013 at 8:03 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Go with bilstein 5100s instead of a spacer lift, check out the suspension sub forum or try searching 5100s. Spacer lifts can cause your shock to bottom out before the bumpstops stop uptravel, spacer lifts have been known to snap and bend shocks if you offroad
  8. Mar 18, 2013 at 3:01 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    even smoother, downsouth motorsports offers the Icon progressive AAL..... 1.5" without overload, or 2" with overload.
    much smoother ride than a single aal.....I am glad I had both, now I can say I have felt the difference first hand.
  9. Mar 18, 2013 at 3:29 AM
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    I did a 3 leaf progressive AAL, from Wheelers(no TSB) left over load in gives me a slight rake, with front setting at 1.75, I'd stay away from blocks. The ride is softer then OEM, and I can hook up my 4-wheeler trailer ,with no bro-lean
  10. Apr 3, 2013 at 9:37 AM
    des0011
    des0011 New Member
    Utah
    TRD Off Road 4x4
    Thanks for the advice, any idea on what setting to use to level it out. I'm going to be putting an ARB Bull Bar on at some time so I'll probably need to go a little high to account for the sag.
  11. Apr 3, 2013 at 9:37 AM
    des0011
    des0011 New Member
    Utah
    TRD Off Road 4x4
    Setting for 5100's that is.
