LIFT HELP WANTED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by m.reed.1, Dec 16, 2012.
  1. Dec 16, 2012 at 6:47 PM
    m.reed.1
    m.reed.1 [OP] Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    I have a '13 sport and im looking just for a slight lift, something that wouldnt look bad with my stock tires until i can get new rims and tires. maybe a 2-3''. just something to give me a little better stance and clearance while maintaining the same suspension feeling and performance, or better performance
  2. Dec 16, 2012 at 6:49 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Get bilstein struts all around. Anything else like spacers will just make the ride worse.
    Edit: Not everything else, but anything cheaper than that. You can get high quality lifts for way more money
  3. Dec 16, 2012 at 7:06 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    someone mentioned a spindle lift, what would that do. also, would i just need to change the struts on my truck with the bilstein swap?
  4. Dec 16, 2012 at 7:30 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Spindle lifts are for PreRunners only & replaces the spindles (between upper & lower control arms) with a longer one.
    Bilsteins would require swapping out all shocks and you could reuse stock coils or get longer ones so you wouldn't have to preload them. You would also need an add a leaf or new leaf pack for the rear unless you just wanted to level it.
    I would recommend OME instead of billies. 885s on OME shocks & an AAL or the Dakar leaf pack. You'll get 2.5"+ (2.5" for DCLB more for DCSB) up front without a spacer & 2" or 3" in rear depending on AAL or leaf pack.
  5. Dec 17, 2012 at 9:12 AM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    yeah i have a pre runner, im not looking for much of a lift, just a little more clearance with a similar feel in handling and ride comfort
  6. Dec 17, 2012 at 9:56 AM
    4Wheelin4Banger
    Randy
    So you could go with ether the spindles or OME.
    OME 884s have the same sring rate as the 885s just a little shorter. Maybe around 2" on yours.
    I love the ride of my OMEs (coils & shocks are designed to go together and work great on our trucks) both on & off road. A little firmer than stock but not harsh (even better without the sway bar).
