lift help
Discussion in '1st Gen. Tacomas (1995-2004)' started by maycraft2300, Sep 16, 2010.
  1. Sep 16, 2010 at 7:11 PM
    maycraft2300
    maycraft2300 [OP] New Member
    north Carolina
    02 Tacoma trd
    Hey guys. I have a question. Do you guys know if it will work to use the truxx 3inch lift wit coil spacers. Here is the thought the truxx lift is the block that sits on top of the strut tower. It has the diff drop brackets to realign the drive angles. I was thinking about also doing the 2inch aluminum spacers in the coil springs as well. Will this work or am I looking for trouble. If I do this it will supposedly give me 5 inches of lift. I want to run 35's would it be better for me to do the truxx lift and a body lift? I am fixing to order my lift. I cannot afford a true 6inch suspension lift even though I know this would be the best way. Thanks for your replies.
  2. Sep 16, 2010 at 7:13 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    NO! don't buy it.
  3. Sep 16, 2010 at 7:17 PM
    JLee
    Jerry
    Grass valley CA
    First of all don't do a body lift unless it's under an inch.
    Just go for a 3" Suspension lift the spacers are going to be crap and will just cause you problems.
    and another thing if you do 5" of spacers your CV joints are going to go by by fast there is no way you can get them at the right angle without a drop bracket.
  4. Sep 16, 2010 at 7:18 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    x2 this man knows what hes talking about!
  5. Sep 17, 2010 at 7:37 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    x3 Just save your money if you are going to do a 4" or 6" lift, it is well worth it down the road. I am learning that the hard way right now...
    BTW look at name brands for this 4" to 6" lift such as Pro Comp and Fabtech they give you everything you will need.
  6. Sep 17, 2010 at 9:33 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    drop bracket or sas is the only way youll fit 35s. you cant drop the diff enough without cutting your crossmember and lowering the t case to realign the cvs. if you dont have money now and its what you really want save dont worry about the cost if its what you want. i tried saving a few bucks and im ending up spending more than it would have cost me to just throw in some parts in the first place
  7. Sep 17, 2010 at 11:06 PM
    AlexXx
    AlexXx Well-Known Member
    Louisiana
    99 taco
    All-Pro 3" Rear kit, Camburg Coilovers, 1" RB BL, 285/75/16's, and rear Lock Right locker Collecting 4wd parts to convert.
    You can run 35's with a 3" lift. Trim you fenders! Do you have a 4banger or v6? Gear ratio? I see that you have a trd taco, so guessing 4.30? or 4.56?
  8. Sep 18, 2010 at 8:24 AM
    malander
    max
    01 limited trd 4x4
    damn id like to see that...maybe ill have to give it a try :) lol i believe trd v6 has 4.10s but not positive on that one
  9. Sep 18, 2010 at 7:06 PM
    AlexXx
    Louisiana
    99 taco
    Well I have a trd 4 cyl with 4.30's. You'll like to see 35's with trimmed fenders and 3" lift? if so, here ya go:
  10. Sep 18, 2010 at 8:41 PM
    malander
    max
    01 limited trd 4x4
    theres body lift and sus. lift though:) but 37s are freakin impressive
  11. Sep 18, 2010 at 8:56 PM
    AlexXx
    Louisiana
    99 taco
    And? Still had to trim the crap out of the fenders and bed. The OP is asking how to fit 35's with a 3" lift...there's the answer. Even though they are 37's, same concept.
    Here's another one:
  12. Sep 18, 2010 at 8:57 PM
    randombob
    randombob Well-Known Member
    Eureka, CA
    2013 TRD OR
    stuffs
    those're 37's according to the specs!
    Nice but I'd hate to have to 'trim' that much of my truck off.
  13. Sep 18, 2010 at 9:18 PM
    AlexXx
    Louisiana
    99 taco
    I know that's 37's, didn't say they weren't? Point it, if you can make 37's fit then you can fit 35's....just showing it's possible with a small lift. If you wheel you wheel hard, do you care about body damage? No, but assume this guy doesn't and it's more for show.
  14. Sep 21, 2010 at 6:30 PM
    malander
    max
    01 limited trd 4x4
    anything is possible if you put your mind to it. i guess i just couldnt fathom cutting up a perfectly good truck to fit 35s unless its a trail rig or the like. hope we answered your question op it can be done...but at the price of your fenders. if you need any good recommendations for your lift dont hesitate to ask and theres always the search function :thumbsup:
