LIFT HELP!?!?!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mh.meier, Oct 29, 2011.
  1. Oct 29, 2011 at 11:31 PM
    mh.meier
    mh.meier [OP] PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I just got Bilstein 5100's installed on the front end and there was no difference int he height even though I was asured there would be. Even if there had been a differenceI still want a bigger lift. I am on a budget and I am not into hardcore off roading, just getting into it actually? Any suggestions?
  2. Oct 29, 2011 at 11:37 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    What are they set at? Stock springs?
  3. Oct 29, 2011 at 11:55 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the front 5100's provide lift depending on where the coil sits on the coil perch. There are rings on the 5100's that allow you to change the coil perch position;
    did you leave them at the lowest "stock" setting? if you did you will not see any lift
  4. Oct 29, 2011 at 11:57 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Poi boi pineapple lover is correct
  5. Oct 30, 2011 at 12:06 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I'm also assuming you did not buy lift coils.
    take it back to the shop and have them change the settings. It will require compressing your coils.
    when I'm not BSing, I'm actually helping people!
  6. Oct 30, 2011 at 12:29 AM
    4Wheelin4Banger
    Randy
    Cody comes back from Exile Island a new man. Or was this your one good deed for today?
  7. Oct 30, 2011 at 12:33 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    i never went anywhere...I live here....:D
    I think a good 1/3 of my posts are about 5100's, tire sizes, KM2's, and lifts..
    or not, but still
