Lift Help.....
Discussion in 'Suspension' started by 09 Redneck, Mar 10, 2012.
  1. Mar 10, 2012 at 5:55 PM
    09 Redneck
    09 Redneck [OP] Well-Known Member
    Ga
    As my truck sits know it has 5100s set at zero with Eibachs up front, 5100s and 1 1/2 block in the back. No TSB. The front sits about 1 3/4 inches lower in the front. I dont want to preload the front, so what would be the best option to get it close to level? I want to try the 885s set at zero but dont want the front higher. Any help? Thanks...
  2. Mar 10, 2012 at 6:28 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    I have the 885's up front and got 2.7" of lift ...I have the tsb to the rear with the 1.5 aal made for tsb...I am 3/4" higher in the rear
  3. Mar 10, 2012 at 6:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Crank your billies to .85
  4. Mar 10, 2012 at 6:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    this
    preload is incompatible with 1st gens, on 2nd gens theyre fine
