Lift help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Daddy_Rabbit99, Dec 20, 2008.
  1. Dec 20, 2008 at 7:20 PM
    Daddy_Rabbit99
    Daddy_Rabbit99 [OP] Active Member
    I am wanting to get a 3" inch lift from toytec. What would you recommend that I need? Thinking about getting the 3" lift with front spacers and rear aal. This is my daily driver. Help and opinions are appreciated.
    Thanks in advance.
  2. Dec 20, 2008 at 7:26 PM
    Daddy_Rabbit99
    Is that on toytec?
  3. Dec 20, 2008 at 7:28 PM
    Daddy_Rabbit99
    Sorry should of put that on there. I have an 05 DC sb
  4. Dec 20, 2008 at 7:29 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
  5. Dec 20, 2008 at 7:32 PM
    Daddy_Rabbit99
  6. Dec 20, 2008 at 7:33 PM
    Daddy_Rabbit99
    Any other advice?
  7. Dec 20, 2008 at 7:33 PM
    LonghornTaco
    Minnesota
    You can, but you'll get a much better ride by swapping out your shock up front with the OME shocks.
  8. Dec 20, 2008 at 7:34 PM
    LonghornTaco
    Minnesota
    new UCAs are a very good idea... It will allow you to get a proper alignment.
  9. Dec 20, 2008 at 7:36 PM
    LonghornTaco
    Minnesota
    Oh yeah - forgot about that one... Good call!
  10. Dec 20, 2008 at 7:38 PM
    Daddy_Rabbit99
  11. Dec 20, 2008 at 7:39 PM
    LonghornTaco
    Minnesota
  12. Dec 20, 2008 at 7:41 PM
    Daddy_Rabbit99
    are these necessary? just trying to get a ruff estimate on what i need to save up. :D
  13. Dec 20, 2008 at 7:44 PM
    LonghornTaco
    Minnesota
    Can you run your truck without replacing them? Yes. But, you're going to wear out your ball joints. Here's a thread concerning this:
    http://www.tacomaworld.com/forum/suspension/20583-reason-after-market-ucas.html
    Also, you're alignment won't be quite right, so you'll probably have uneven tire wear.
  14. Dec 20, 2008 at 7:46 PM
    LonghornTaco
    Minnesota
    285s on stock rims rubbed my Total Chaos UCAs - that's why I got wheel spacers. Not sure if this is a blanket statement on all 285s, but it was in my case. 285s on aftermarket rims with at least a 4.5" backspace should clear them.
  15. Dec 20, 2008 at 7:48 PM
    Daddy_Rabbit99
    Yeah prob stock for a little while. But who knows. May get wheels and tires before then. lol.
  16. Dec 20, 2008 at 7:57 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I got a set of Readylift spacers. But, Im about to make a hefty purchase through toytech and go with their coilover's and a bunch of other goodies.
    Am I happy with the spacers, well yeah. It let me run my 33's for a year with no probs. Even went up with the fellas to the Uwharries with just the spacer up front and all went well.
    But, "yup there is a but". I got to say that it is not a suspension upgrade. I like to look a it as us Medics would say "a STOP GAP". It is a temporary solution to a needed improvement.
    If bigger tires and no compromise in ride quality is exactly what you want, stay away from these... If you just want a cheap economical way to fit larger tires on your truck, and dont care much for offroading, or not too picky of with a harsh ride, then why not...:D
    You pay for what you get. Im sure you heard it multiple times, but it's true.
    My Readylift top plate spacers will be avaiilable late Jan early Feb, just FYI LOL...
  17. Dec 20, 2008 at 8:02 PM
    Daddy_Rabbit99
    Well the only offroading I will be doing is getting to my deer stand or maybe chasing a turkey in shawnee forest. But really just going for looks. I know I will catch heat for this. :D
  18. Dec 20, 2008 at 8:09 PM
    roxspin72
    NC
    Oh Yeah!!!
    Dont let no one give you a hard time for choosing your mods. Not everyone is ready to get into a competition lift. Luckily Toytech, Walker Evans, and Sway Away are making this a more affordable lift. Until then, go with what works for your needs. And, if quality somewhat lingers in the back of your mind; the OME's are Known to perform and are way more affordable. Just be prepared for a more complicated install...
    Good Luck.
  19. Dec 20, 2008 at 8:15 PM
    LonghornTaco
    Minnesota
    +1
  20. Dec 21, 2008 at 8:43 PM
    MtnTacoma
    MtnTacoma New Member
    Longhorn Taco,
    I'm new here and have been burning the midnight oil the last few days researching lifts of all sorts. The conclusion I came to is basically the set up you have, and your truck looks great by the way.
    I have an 05 TRD offroad access cab 6 speed, black, no mods yet at all.
    I was hoping you could help with a few questions:
    1. Did you do an AAL and upgraded shocks in the back? I was thinking of going with an AAL and the 5125's, but not sure yet?
    2. Did you do the install yourself? I've never done this type of work on my truck at all, but with the Toytec pre built coilovers I think I can handle it. Is it simply a matter of jacking it up, swapping out the old coils and shocks and sticking in the new ones?
    3. How hard is it to do the TC UCA install? Keeping in mind a "moderate" mechanical ability on my end.
    4. What were your final lift heights in the front and back?
    That's about it for now. Thanks.
