Lift Help
Discussion in 'Suspension' started by 764mike, Jun 28, 2009.
  1. Jun 28, 2009 at 10:49 AM
    764mike
    764mike [OP] Well-Known Member
    NJ
    2008 Toyota Tacoma Double Cab
    I am a newbie to Tacoma ownership and need a little help. I would like to add a 3 inch lift and fill the gap with bigger wheels and tires. Can anyone steer me in the right direction with the lift part of the mod. I dont want to spend a ton of money and I want to keep the truck riding as good as stock. Thanks.
  2. Jun 30, 2009 at 5:35 AM
    764mike
    NJ
    Thanks for the info. I went on the old man web site. Are you suggesting the complete suspension kit.
  3. Jun 30, 2009 at 12:41 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    the whole kit would be good, but coilover are great since you can adjust the front height. Listen to Timmer, he knows what he is talking about.
  4. Jun 30, 2009 at 1:10 PM
    764mike
    NJ
    Are you talkin about the lift spring and shock assemblies. I am a newbie so I want to be sure. Thanks for your patience. OME has it listed as two seperate items.
  5. Jun 30, 2009 at 1:55 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    OME is good for the lift aspect but if you have a brand new truck, I would not go with OME setup. I did with only 1,500 miles on my truck and the ride was terrible. Yes, worse than stock. I sold shortly after. But if you have a truck with a few miles on it, the ride might not seem so bad.
  6. Jun 30, 2009 at 3:37 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I have the toytec ultm Lift kit it came with every thing you'll need then I added the Total Chaos ucas I the ride is just as good if not better than stock.
  7. Jun 30, 2009 at 4:49 PM
    bajamoon
    STEVE
    Whittier
    you have alot of options, it all depends on your budget, how much do you have in mind so we can help you out more.
  8. Jun 30, 2009 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    WOW.. First I have heard of an OME set up giving a bad result. Everyone I know is really happy with the OME set up, as am I. My "only" complaint, is that I sometimes think its just a little too soft.
  9. Jun 30, 2009 at 5:04 PM
    764mike
    NJ
    I would like to keep it around $1000 if possible. A little more wouldn't break the bank.
  10. Jul 1, 2009 at 3:40 PM
    bermise
    Houston
    08 TRD off road
    OME coils and shocks would probably be your best bet. And any brand of add-a-leafs in the back.
