Lift help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trentarredtaco, Aug 19, 2017.
  1. Aug 19, 2017 at 8:45 AM
    Trentarredtaco
    Trentarredtaco [OP] Active Member
    Trent
    2005 4 Door red tacoma
    Bigger tires roof rails
    I wanna do a bigger lift on my truck. Right now I have just a 3" toy Tec lift. I want to maybe go up to a 6" lift any suggestions that won't break the bank?? Second gen Tacoma
  2. Aug 19, 2017 at 8:48 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If you don't break the bank, then you'll break the truck.
  3. Aug 19, 2017 at 8:50 AM
    Trentarredtaco
    Trent
    I'm up for anything just have to save and make it look good c
  4. Aug 19, 2017 at 9:31 AM
    moondeath
    Pa, Gardners
    If you go higher than you are now, then you'll need adjustable UCAs. They'll be about $400-$600 for the set. I can't speak for parts going up to 6" of height, but to do it right won't be cheap.
  5. Aug 19, 2017 at 9:33 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    OP are you 4x4 or a prerunner?
  6. Aug 19, 2017 at 12:36 PM
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
    Just Go SAS...:boink:
  7. Aug 19, 2017 at 12:46 PM
    Trentarredtaco
    Trent
  8. Aug 19, 2017 at 1:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You're stuck with a drop bracket lift then. Be aware this involves cutting out your cross member (part of your frame) and welding the lift bracket in place. None of this is going to be cheap, and it's not easily reversible if you ever decide that.
