lift help
Discussion in 'Suspension' started by streetcustoms, Sep 21, 2009.
  1. Sep 21, 2009 at 5:44 PM
    streetcustoms
    streetcustoms [OP] Well-Known Member
    tujunga , ca
    prerunner sr5 trd off road
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74196-my-build-so-far.html
    i have a toytec 3 inch lift with 885 coils and add a leaf i wanna get about an inch more of a lift can i add bigger spacers up front and blocks on top of the add a leaf
    willl i have any problems with anything
  2. Sep 21, 2009 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You shouldnt do that. If you need more than 3" lift, you need to consider a drop braket lift
  3. Sep 22, 2009 at 8:30 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    or a body lift if your desperate, but i'd just call it good w/ what ya got
  4. Sep 22, 2009 at 8:35 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    body lift = danger! so dont push it. if you do youlle mess up your joint and your truck will look jank with really bad camber!
