lift help!!!!!!!!!!!
Discussion in 'Suspension' started by justinfox3110, Feb 17, 2010.
  1. Feb 17, 2010 at 5:54 PM
    justinfox3110
    justinfox3110 [OP] Well-Known Member
    justin
    beckley wv
    07 speedway blue 6 spd
    i hope i did this right...
    i was just wondering if this would be a good lift...
  2. Feb 17, 2010 at 5:59 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    No, lose the spacers/ blocks.
  3. Feb 17, 2010 at 5:59 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I know alot of people like the billstein 5100's. The blocks the lift comes with are kinda cheap. If you wanna do it right either get aal or a new leaf pack but your gona have to spend extra money.
  4. Feb 17, 2010 at 6:06 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    whats up justin! my name is Hayden and i live in eastern ky not far from you.(about three hours) personally i don't recommend spacer lifts. not sure how much they are asking for that setup but for just a little more money you can get a really good lift.(around 700 bucks)
  5. Feb 17, 2010 at 6:12 PM
    justinfox3110
    justin
    beckley wv
    this setup is $319
  6. Feb 17, 2010 at 6:16 PM
    TacoSupreem
    Hayden
    Kentucky
    thats a good price. its do-able but not the best way to go.
  7. Feb 17, 2010 at 6:17 PM
    TacoSupreem
    Hayden
    Kentucky
    if you are wanting to wheel your truck(as i am assuming you will based on where you live) this is not a good idea.
  8. Feb 17, 2010 at 6:17 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    not a good lift. look at toytec.com for better options
  9. Feb 17, 2010 at 6:21 PM
    justinfox3110
    justin
    beckley wv
    im gonna offroad a little but not rediculous amount...
  10. Feb 17, 2010 at 6:24 PM
    tacomakid96
    Phil
    Out n' about
    If you only have 300 bucks to spend and you really want your truck lifted then do it and you might like it and you might not. My mind tells me save your money and buy a good lift from toytec.
  11. Feb 17, 2010 at 6:25 PM
    TacoSupreem
    Hayden
    Kentucky
    i'm just sayin there is alot better stuff out there. those bilsteins are good shocks but the spacers and blocks will only cause you grief.
  12. Feb 17, 2010 at 6:27 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Get a 3" revtek suspension lift, they are great for Toyotas.
    (coming from personal experience, it is a good lift and Ive never had problems)
  13. Feb 17, 2010 at 6:30 PM
    justinfox3110
    justin
    beckley wv
    this ome kit is a good one and this is everything i need to lift 3"
  14. Feb 17, 2010 at 6:31 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    ^ that's what I've got, tons of guys here run that same setup.
  15. Feb 17, 2010 at 6:37 PM
    TacoSupreem
    Hayden
    Kentucky
    yeah, there you go!
  16. Feb 17, 2010 at 6:38 PM
    justinfox3110
    justin
    beckley wv
    then that sounds like the one ill prolly get, just have to save a lil longer...
  17. Feb 17, 2010 at 6:38 PM
    TacoSupreem
    Hayden
    Kentucky
    yes with the 885's u will have 3 inches of lift up front
  18. Feb 17, 2010 at 6:40 PM
    TacoSupreem
    Hayden
    Kentucky
    i have the same kit basically with exception of the aal.
  19. Feb 17, 2010 at 6:46 PM
    justinfox3110
    justin
    beckley wv
    will 285's fit ???
  20. Feb 17, 2010 at 6:48 PM
    CopDoctor
    Trinidad, CO
    you could also just get this kit (without shocks you should use 884 coils)
    then you can upgrade the shocks seperately down the line
