LIFT IDEAS TO FIT 33'S
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLTACOMA32818, Sep 23, 2017.
  1. Sep 23, 2017 at 9:44 AM
    FLTACOMA32818
    FLTACOMA32818 [OP] New Member
    JACK
    2009 TACOMA TRD OFF ROAD
    2" FRONT LEVEL, 285/60/18 NITTO GRAPPLERS, 1.5IN WHEEL SPACERS, TOUCH SCREEN PIONEER, 10IN CUSTOM FIT SUB, NEW FACTORY REAR SPRINGS
    HAVE 285/60/18 WITH AFTERMARKET RIMS, 1.5 SPACERS, AND 2"LEVEL UP FRONT. WITH THAT STILL RUBS AT FULL TURN. WAS THINKING SPINDLE LIFT WITH A 4 INCH REAR BLOCK. WILL THAT CLEAR AND WHAT ABOUT ABS SENSOR FOR THE FRONT?
  2. Sep 23, 2017 at 9:45 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    WHY ARE WE YELLING??
    spindle lift will only work with Prerunners, I think..
    what offset/backspacing are your wheels?
    Roland79, 303tacoma and doorsidedown like this.
  3. Sep 23, 2017 at 9:48 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  4. Sep 23, 2017 at 9:49 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    What does it rub on?
    Seems most people need to do a bunch of cutting/trimming/hammering to get 285s to fit.
    Welcome to TW
    fatfurious2 likes this.
  5. Sep 23, 2017 at 9:52 AM
    Pigpen
    Dan
    Northwest Montana
    Cab Mount Chop
    Trim any plastic that rubs too
  6. Sep 23, 2017 at 10:10 AM
    FLTACOMA32818
    JACK
    I'm sorry about the caps. No yelling here. It is a prerunner. The 285's are going bye bye. But the 2 inch level states it clears 32's, bit I guess not in 285 width. I just want to get the right set up without the rub going to 33's. I'll keep the 2 inch +the spindle=6 inch. The rear at 4"will keep it level. Just can't have the front rub.
  7. Sep 23, 2017 at 10:12 AM
    FLTACOMA32818
    JACK
    Jibbs, the 285's rub on the metal frame at the rear of the front frame work. Plastic was trimmed and mud guards removed already.
  8. Sep 23, 2017 at 10:13 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Then I would definitely go Maxtrac Spindles since you are a Pre Runner @ChadsPride help him out.
    BassAckwards likes this.
  9. Sep 23, 2017 at 10:15 AM
    FLTACOMA32818
    JACK
    I plan on Maxtrac spindles, but I hear the abs sensor wires are not long enough for the upgrade. Any idea there?
  10. Sep 23, 2017 at 10:15 AM
    doorsidedown
    doorsidedown Well-Known Member
    @ChadsPride - OP, follow this mans example if you want to lift your prerunner...
  11. Sep 23, 2017 at 10:15 AM
    doorsidedown
    Damn you beat me to it lol
  12. Sep 23, 2017 at 5:26 PM
    TacoTacoma97
    TacoTacoma97 Eagle Scout
    Scott
    Waco TX
    I think it's a Tacoma, let me go check again...
    *Cracks knuckles* Where do I begin?
    I've got a 3 inch lift and 285/75/16s if that means anything.
  13. Sep 23, 2017 at 6:46 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    No it doesn't because you basically have him useless information. Sorry that sounds harsh, I am just kidding. But for real without stating how you made the tires fit it doesn't help the OP at all.
    EatSleepTacos likes this.
  14. Sep 23, 2017 at 6:49 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I ran 285/75/16 on 2.5" lift with minimal rubbing but I had aftermarket UCAs, dialing in caster helped a lot. Finally had my cab mount chop done and won't scrub again after that (now running an inch more of lift but CMC would've fixed it without the lift).
  15. Sep 24, 2017 at 7:19 AM
    TacoTacoma97
    Scott
    Waco TX
    I used an ICON stage 1 lift that is 3 inches in the front with Toytec progressive AAL 2 inches with the factory overload removed. Fits perfectly. Oh and no one gives a crap about your personal anecdotes so next time you post, remember that.
  16. Sep 24, 2017 at 7:45 AM
    Pigpen
    Dan
    Northwest Montana
    Pull out the front shocks, put the wheels back on, and set the truck back on the ground. Turn the steering wheel from lock to lock. Cut off anything the tire touches. Put the shocks back on. You'll never rub again.
    Harry and Justinlhc like this.
  17. Sep 24, 2017 at 7:50 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    You need to cut, not lift more. A lift kit does not change the path the wheel travels when the suspension cycles. Sounds like you need a cab mount chop.
    Before you do anything though, get a new keyboard because it appears that your caps lock is broken.
    rollin904 and Hairy Taco like this.
  18. Sep 24, 2017 at 7:59 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    What size tire do you plan to replace the 285s with? I'm running 255/85/16 and rub only on full turn going over bumps (mudflaps). Im running 5100s with 884s set at 0 in the front, AAL in the rear, stock wheels with Spidertrax spacers.
    Bumper is trimmed.
  19. Sep 24, 2017 at 8:06 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Cut wherever it rubs then drink a cup of coffee.
    rollin904 likes this.
  20. Sep 24, 2017 at 3:51 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Your an angry elf. Don't be mad at me because your post was useless to the OP.
