Lift Install Cost
Discussion in 'Suspension' started by vataco19, Jun 22, 2011.
  1. Jun 22, 2011 at 8:05 AM
    vataco19
    vataco19 [OP] Member
    How much should i expect to pay for a toytec coil lift with aal for install? Including alignment and tire install
  2. Jun 22, 2011 at 8:28 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Your best bet would be to call a local shop and get some quotes. Install prices would very by region. If they're a proficient shop, I would guess 3 hours for the lift + alignment + tire install.
    Average about $100/hr for a shop rate depending on where you go, expect $300 if they have to assemble the coils. Should be a bit cheaper if you buy the coils/struts pre-assembled. If you get the struts pre-assembled, the install isn't that bad and you could save some money by installing yourself.
    Alignment can range from $50 - $100 depending on the shop.
    Shops here mount tires for between $10 and $15 per tire (excluding old tire disposal fees). You might get a better deal if you bough the tires from the shop doing the work.
    EDIT: Take this with a grain of salt, this is a rough idea only. I did mine myself so I'm guestimating based on what I would guess a shop could do.
  3. Jun 22, 2011 at 8:31 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Yea just do it your self. there are how to threads on here that explain everything. I don't trust anyone else to work on my truck.
  4. Jun 22, 2011 at 8:43 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    My lift cost $460 a shop told me they could install it for around $400 and 8hrs. My alignment was $90.
    I installed my lift at home in less than 8hrs and I never installed a lift like this before.
    I don't have an estimate for tire install.
  5. Jun 22, 2011 at 11:25 AM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Eibachs w/ 5100's set at 0, Rear TSB, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, 265/75/16 Hankook Dynapro ATM Tires, Elusive Elements Mesh Grill
    I know this isn't exactly what you are having done but I paid $400 for the shop to intsall lift springs, front shocks, and rear shocks. The labor rate was $79 and it took 5 hours. Did I pay too much? Probably. Could I have done it myslef? Maybe. But I felt that the time spent away from family and friends outweighed the money spent on having the shop do it. Sometimes the intagibles win.
  6. Jun 22, 2011 at 11:29 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You can't spend 5 hours away from your family friends :confused:
    You payed too much when I installed my lift is only took 3 1/2 hours and we had major problems with the U bolts.
  7. Jun 22, 2011 at 11:33 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Install the lift with your family/friends :cool:
  8. Jun 22, 2011 at 11:35 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    It's super easy, it took me and my friend around 4 hours to put mine on that's including going to a shop to get acess to a strut compressor.. I wouldn't bring my truck to a shop to get it lifted... You don't know if they did it right... A couple hours with a friend working on your truck out weighs spending 400+ on a install.
  9. Jun 22, 2011 at 11:38 AM
    JLee
    Jerry
    Bay Area NorCal
    Hell yeah that money could be put towards better parts.
  10. Jun 22, 2011 at 11:38 AM
    Pugga
    Massachusetts
    Cheap labor!
    An dpak, I see your in Richmond, when I was there I took my truck to Ray Tuck's. Not sure if he's still there, but if the shop is still opened and Ray is still running it, they're good guys and always treated me fairly. His garage serviced the whole fleet of vehicles for the company I worked for as well as my personal truck. He does good work and his pricing always seemed fair.
  11. Jun 22, 2011 at 11:41 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    lol do you have a job?
  12. Jun 22, 2011 at 11:44 AM
    rwalker
    rwalker Well-Known Member
    Rian
    Portland
    Tacoma Baja TX
    I had 4 wheel parts do my toytec ultimate for $275. No problems with it, its been on for about 2 years.
  13. Jun 22, 2011 at 11:47 AM
    dpak
    Richmond, VA
    Pugga - I wished you would have told me about Ray earlier. I took it truck outfitters. Like I said, it was a bit pricey.
    To everyone else, the work week is too long and the weekends are too short for me and its summertime. I would rather take my niece to the park or go fishing with her and my friends. It's just how I see things.
  14. Jun 22, 2011 at 12:43 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    x2 on do it yourself, unless you're scared!!!... :p
  15. Jun 22, 2011 at 3:46 PM
    vataco19
    i actually am in richmond too. who did you take it to?
  16. Jun 22, 2011 at 3:50 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    you need pics and price as per TW rules.
  17. Jun 22, 2011 at 3:51 PM
    samsung
    George
    Sugar Land, Texas
    sorry about that i saw the pics.
  18. Jun 22, 2011 at 3:53 PM
    vataco19
    im actually in richmond. how much did ray tuck charge you?
  19. Jun 22, 2011 at 8:09 PM
    dpak
    Richmond, VA
    Is that question directed towards me? If so, I did not take it to Ray's. Pugga recommended him but does not know if he still has a shop. I went to Brian Allen's Truck Outfitters.
