Lift Install/Dealership
Discussion in 'Suspension' started by NCSlang, Oct 4, 2012.
  1. Oct 4, 2012 at 12:24 PM
    NCSlang
    NCSlang [OP] Member
    Harper
    2012 Toyota Tacoma TRD
    Auto Starter, 3" Lift, Custom Rims/Tires, System
    I called my dealership about a possible lift kit installation, who then informed me Toyota does not partner with any company that makes/sells lift kits for Toyota tacomas. Buying/installing one would then void my suspension warrenty if I did decide to install..anyway around this?
  2. Oct 4, 2012 at 12:26 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    x2....buy it and have someone help you install....if you lived close i could do it for you
  3. Oct 4, 2012 at 12:35 PM
    NCSlang
    NCSlang [OP] Member
    Harper
    It's a bunch of BullS*it. I wont be getting it done before winter hits but i'll like to have all my ducks in a row with everything ready for when spring comes around again. I'll probably buy it online and hold on till spring, toyota has already screwed up a few things on my truck and it's only 5 months old
  4. Oct 4, 2012 at 12:37 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    yes..where do you live? TW is full of helpful people..Mod days are very popular here.
  5. Oct 4, 2012 at 12:38 PM
    anthony250f
    Anthony
    San Diego, CA
    ....and your a female so i gurantee someone will......
  6. Oct 4, 2012 at 12:38 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    It's the dealership's call whether or not they want to install parts brought in from somewhere else. Some privately owned shops also won't install parts unless you purchase through them.
    As far as the warranty, it's accurate. Toyota won't warranty an aftermarket part or any part that an aftermarket part caused to fail.
    I guess I'm not seeing where there's a big issue here... I'd find another local shop willing to install your lift. If you can find a 4x4 shop or off road shop, they'll likely do a better job of it anyways as they'll be familiar with the components.
  7. Oct 4, 2012 at 12:39 PM
    NCSlang
    NCSlang [OP] Member
    Harper
    North Dakota. great place for trucks with all the snow we get. Been doing some research and havent set in stone if I want a 3 or 6" put on
  8. Oct 4, 2012 at 12:41 PM
    NCSlang
    NCSlang [OP] Member
    Harper
    I'd be going to one of those if I wasnt stationed in such a small town where there are NO off road shops that Im willing to leave my truck with. I'm not extreamly familiar with the after market parts/warrenty issue.
  9. Oct 4, 2012 at 12:43 PM
    boardude
    boardude BOOMSHAKALAKA
    Kris
    Tucson, Arizona
    '15 Tundra TRD Pro Inferno
    A Yota with more cowbell
    ^^^ This exactly.. My dealership had no problem throwing in an AAL from Toytec for me when they did the TSB, but they specifically mentioned that it would not be covered under warranty. Same if you were to replace out the front shocks and coils, they wouldn't cover those either. Everything else under your warranty is still valid.
