Lift install Finally!
Discussion in 'Suspension' started by 1expensiveTaco, Jan 31, 2012.
  1. Jan 31, 2012 at 7:09 PM
    1expensiveTaco
    1expensiveTaco [OP] Active Member
    Steven
    Washington
    07 Tacoma Access Cab 4x4 V6
    Whats up guys and gals, I'm finally lifting my ride (07 AC 4x4 sr5)
    Here's My List;
    UpFront
    1)OME 90000 Nitro Charger Shocks
    2)OME 885 Coils
    3)10mm Lift Enhancer
    In The Rear (ha)
    4)OME Dakar Leaf Spring (CSO47R)
    5)OME 182 shocks
    6)Toyotec 3 Degree Axel Shims
    7)OME Drive shaft Packer Kit (FK29)
    8)New U-Bolts, New Toyota Bushings
    I DO NOT have new rims or tires, this will be my first time Fkucnig around with suspension but I'm not to worried about it; i do however want to double check with you lovely folks here on TW to make sure i got what i need!
    On that note - will i be in the clear if i keep my stock rims and tires? Or will i need wheel spacers etc. Looking forward to any and all feed back
  2. Jan 31, 2012 at 7:13 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    looks like you got everything. as long as your not running bigger than 32 inch tire on the stock rim your shouldnt have to do anything. If you go with a bigger tire, you may need to do a cap mount chop, or possibly wheel spacer/ new rims with different offset to prevent rubbing..
    pics or it didnt happen :)
  3. Feb 1, 2012 at 11:46 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    Might want to look into extended brake lines for the rear!
  4. Feb 1, 2012 at 11:53 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Get centre pin collars or you won't be able to use the axle shims with the Daks
  5. Feb 1, 2012 at 12:25 PM
    1expensiveTaco
    Steven
    Washington
    tacoma16 - Id op for new rims :rolleyes: but might have to stick with stock for a bit, 32s will be clean... PICS asap!
    BVCOTaco - I want to... My impatience tells me to flex it first see how i feel about the stock ones....
    OZ-T - Thanks Ill look into it!
  6. Feb 1, 2012 at 12:31 PM
    1expensiveTaco
    Steven
    Washington
    Wow I'm def getting those pin collars!
  7. Feb 1, 2012 at 12:54 PM
    OZ-T
    Peter North
    British Columbia
  8. Feb 1, 2012 at 1:36 PM
    1expensiveTaco
    Steven
    Washington
