Lift Install - Should I be Concerned??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PreRunner, Mar 1, 2010.
  1. Mar 1, 2010 at 3:17 PM
    PreRunner
    PreRunner [OP] Well-Known Member
    Im having a shop install a lift on my 2010 taco. They're installing icon extended coilovers with camburg uca's and ran across a problem. They said there is a bolt, 12 or 13 inches long, that can only be removed by cutting the bolt, or cutting through the fender. They cut through the fender (i have not seen it yet). They said thats what the directions said to do.
    Also;
    They told me the stock TPMS system is "straight", and the ivan stewart wheels i bought have a slant. So they "mounted them backwards" and said it wouldn't be a problem unless i have the tire removed from the rim and didn't tell the tech it's backwards.
    Should I be concerned? Please advise :(
  2. Mar 1, 2010 at 4:02 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    That bolt is the one that holds ur uca and they didn't need to cut it to get it out. They couldve bent the sheet metal remove it and bend it back.
  3. Mar 1, 2010 at 4:28 PM
    PreRunner
    i will certainly let them know that, thank you.
    are you familiar with the area they "had" to cut? can it be seen? should i be worried about it? They mentioned a three inch hole ...
  4. Mar 1, 2010 at 4:42 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Didn't they read the instructions that came with the TC UCAs? I think it says to bend the inner sheet metal. You mentioned 3" hole. what is that for?
  5. Mar 1, 2010 at 4:43 PM
    PreRunner
    they are camburg uca's. i dont have the instructions they do. they said the hole was to get the bolt out.
  6. Mar 1, 2010 at 5:13 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    some people bend the inner fender metal, and i've heard of some people cut the bolt off and replace it. if you look in your inner fender you should be able to see the hole they cut. it's right in the pinch weld in the inner fender well. it shouldn't be a problem. also that is true with the tpms deal. they will not fit correctly in all wheels. sounds like they made it work. if your light isnt on then your in good shape!
  7. Mar 1, 2010 at 5:16 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    :eek: :eek:
  8. Mar 1, 2010 at 5:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...Cutting is a bit extreme...but if it worked and they patched it up...Whatever.
    No worries on the TPMS either- You could swap the type of sensors...but putting them in backwards works just as well and is cheaper...Just make sure you tell the tech if you ever have tires work done.
  9. Mar 1, 2010 at 5:20 PM
    TacoSupreem
    Hayden
    Kentucky
    check out the sticky on how to install tc uca's in the suspension section. its basically the same install as the camburg's.
