Lift install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Oct 26, 2014.
  1. Oct 26, 2014 at 1:39 PM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Anyone in the Auburn Mass area that knows how to install 5100's on my 2015 Double Cab 4x4? Or can anyone send me to a trustworthy garage in my area that can do it correctly? Thinking about adding the complete put together Toytec Eibach/5100 combo, and the AAL for TSB springs in the rear.
  2. Oct 26, 2014 at 2:01 PM
    Unchained 5150
    Rick
    Auburn Ma
    If I don't plan on doing any wheeling, Will the Rancho Quicklift Leveling Struts work out just fine for leveling purposes?
  3. Oct 26, 2014 at 2:10 PM
    Unchained 5150
    Rick
    Auburn Ma
    Okay my last Tacoma had the pre built Toytec Eibach/5100 combo. I liked it but had to replace my UCA's I don't mind doing all this as long as some place really reputable will do it. No clue or desire to do it myself?
  4. Oct 26, 2014 at 2:14 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    go 5100's @ 1.75 and a rear 1.5 or 2in AAL
  5. Oct 26, 2014 at 2:15 PM
    Unchained 5150
    Rick
    Auburn Ma
    1.75 on my stock coils and the TSB AAL in the rear will level it nicely correct?
  6. Oct 26, 2014 at 3:42 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Yes level and a harsh ride.
  7. Oct 26, 2014 at 3:52 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Why harsh? From reading seems like a lot of people go this route and are happy with it. Also, i thought the 1.75 setting will level it with the rear tab springs without an aal?
  8. Oct 26, 2014 at 4:08 PM
    Unchained 5150
    Rick
    Auburn Ma
    I thought it would level it as well, I could be wrong. I had this set up on my last Tacoma before the full 3 inch lift and I noticed absolutely no difference in ride.
  9. Oct 31, 2014 at 1:00 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    My old setup for reference: 5100 's at 1.75" w/tsb springs.
    Edit:
    As for the ride, i thought it was much better. Most people that complain about the harsh ride have the set at the max setting (2.5") which is a lot of preload on the coils.
  10. Oct 31, 2014 at 1:08 PM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    All I did on mine was add the 5100s at 1.75 on the front, I have the sport package so came with 4 rear leafs. Leveled out nicely.
  11. Oct 31, 2014 at 1:10 PM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    2011 TRD Sport 4x4 with 5100's @ 1.75" in front, TSB leafs in rear with stock shocks. Pretty much dead nuts level and corrected the factory lean with the 13mm spacer on driver side.
    I'm only about 1000 miles in, but I like the ride a lot better. It's firmer, but not "harsh".
    In my opinion it improved my ride quality, it's the way the truck should have been from the factory.
  12. Oct 31, 2014 at 1:16 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    If you have the rear spring TSB, the 1.75" notch will level it out. If you don't have the rear spring TSB, the .85" notch will level it out.
  13. Oct 31, 2014 at 1:43 PM
    Tractorman
    Tractorman Just A Dumb Farmer
    Stupid
    Misery
    2015 DCSB / MGM
    Sub'd and what is TSB?
  14. Oct 31, 2014 at 1:47 PM
    T Fades
    Simi Valley, CA
  15. Oct 31, 2014 at 2:54 PM
    Tractorman
    Stupid
    Misery
    2015 DCSB / MGM
