Lift is in but have a question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 97lt1ta, Apr 17, 2013.
  1. Apr 17, 2013 at 8:40 PM
    97lt1ta
    97lt1ta [OP] Well-Known Member
    Las Vegas
    07 prerunner
    Made a few posts on my lift kit which is a pro comp 3 inch. Finally got everything in but my alignment is off which I figured would happen. But it's got me thinking I screwed up cause its so bad that the front is grinding. The brakes are grinding on the rotor with out it being pressed. I'm taking it to get an alignment tomorrow but not sure if that's with alignment or I screwed up
  2. Apr 17, 2013 at 10:28 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Are the brakes grinding while you are diving down the road in it? It is normal for there to be some rubbing when the vehicle is off. I can't imagine a lift would screw that up though, unless you over torqued the lugnuts so bad that you severely warped the rotors.
  3. Apr 17, 2013 at 10:51 PM
    sr5vic
    sr5vic SR5vic
    '13 Access Cab SR5 4x4
    285/75/16 Duratracs, 16" Konig Countersteer Offroads, 1" Bora Wheel Spacers, Bilstein 5100's, Total Chaos UCA's, OME 884's, Wheelers's Offroad 2" AAL, Wheeler's 10mm Enhancer Kit, Wheeler's Extended Brake Lines, Trail Gear Diff. Breather, TRD Skid Plate, Morimoto XB LED Fog Lights, Ultra Gauge, AVS Step Shields, 2014 Entune Premium Audio Navigation Head Unit, 2014 Steering Wheel Controls, Leer 100XR Canopy, D2S X Beam HID Retrofit with BLHM, Bolt-on Sliders, TRD PRO Grill, Leer 100XL Canopy, US Offroad Winch Mount, SmittyBilt X2O 10k winch
    might of bent a dust shield into the rotor?
  4. Apr 18, 2013 at 3:56 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Have you really heard of somebody tighten a wheel so hard a rotor warps? That's impossible!
  5. Apr 18, 2013 at 10:40 AM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Not personally no. haha and not as severe enough to grind especially. I would think the wheel studs would break or strip first. I have heard of people tightening them enough to cause minor warping though that causes the the brakes to basically pulsate though, but that is usually on small cars with smaller rotors than we have.
  6. Apr 18, 2013 at 12:20 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's set @ 0 with OME 883x coils up front . Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip.
    X2 ^
  7. Apr 18, 2013 at 2:45 PM
    97lt1ta
    Las Vegas
    07 prerunner
    Yup you guys are correct dust shield was a little bent so when the tire was tightened down pushed the rotor into it. Thanks guys feel like an idiot
