lift is in, problem with alignment. HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Telder, Mar 8, 2011.
  1. Mar 8, 2011 at 11:15 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    05 Tacoma TDR Off Road SR5 V6
    2.5" toytec coverover spacer OME 2.5" lifted spring leaf pack
    i own a 05 tacoma 4x4 TRD off road edtion with moto metal 951 black 9mm offset rims. i installed a lift in my truck a few months ago and i love the lift. i put in toytec 2.5 coilover spacers and OME 2.5 rear leaf pack. right after i nstalled the lift i took it for a alignment at my local shop, and they said i ran out of camber adjustment, so i ran the truck like that for a awhile until i seen it was wearing the out side of my tire bad, so i put the factory rims back on for the winter month and send it for a another alignment, and with the factory rim on the truck my alignment is perfect.
    my question is the anything i can buy or do to fix my alingnment so i can save my tires and put my aftermarket rims back on and not break the bank
    thank boys any help would be great
  2. Mar 8, 2011 at 11:16 AM
    sicripp83
    sicripp83 Well-Known Member
    wboro
    sic
    upper control arms
  3. Mar 8, 2011 at 11:19 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    i been told that but they are pretty pricey and i dont know whick UCA to get
  4. Mar 8, 2011 at 11:21 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    LR UCA's are a good bang for the buck
  5. Mar 8, 2011 at 11:22 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    yup LR for the win.....not uniball either
    they can be had for 500 including shipped rough estimate
  6. Mar 8, 2011 at 11:23 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I'm confused. With the stock tires on they can align it, but with the aftermarket wheels they can't? That's the only change? Did they have to adjust the camber with the aftermarket wheels on so the tires wouldn't rub the upper control arm?
  7. Mar 8, 2011 at 11:24 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    what do the aftermarket UCA give you compared to the factory
  8. Mar 8, 2011 at 11:24 AM
    crf69
    Ohio
    ummm yeah
    i bet it settled to out of range adjustments.....as he did get it aligned immediately after install
  9. Mar 8, 2011 at 11:25 AM
    crf69
    Ohio
    ummm yeah
    more room for adjustment to get alignments perfect....
  10. Mar 8, 2011 at 11:26 AM
    Bama_TACO
    Winfield, AL
    He said after the lift he went to get it aligned and they told him he ran out of camber adjustment.
  11. Mar 8, 2011 at 11:26 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    they align the truck with the aftermarket wheels on but my camber ran out and caused my brand new BF'S to wear on the out side badly
  12. Mar 8, 2011 at 11:28 AM
    Bama_TACO
    Winfield, AL
    This doesn't make sense. The truck should align the same regardless of what wheels are on it.
  13. Mar 8, 2011 at 11:28 AM
    OZ-T
    Peter North
    British Columbia
    LR UCA add +2' camber / +2' caster at their neutral setting
  14. Mar 8, 2011 at 11:30 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    i do have a 9 mm outset on my aftermarket rims, that the ownly thing i can think it can be
  15. Mar 8, 2011 at 11:31 AM
    OZ-T
    Peter North
    British Columbia
  16. Mar 8, 2011 at 11:35 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    those are nice but expensive
  17. Mar 8, 2011 at 11:36 AM
    Bama_TACO
    Winfield, AL
  18. Mar 8, 2011 at 11:38 AM
    OZ-T
    Peter North
    British Columbia
    Good luck
  19. Mar 8, 2011 at 11:41 AM
    Bama_TACO
    Winfield, AL
    What size wheels and tires are you running on the aftermarket wheels?
  20. Mar 8, 2011 at 11:41 AM
    Telder
    Telder [OP] Member
    Nine Mile River
    can you get poly urethane bushing
